BuckyBL2025
Nick
Dayton, Ohio
2025 Ford Bronco Sport Badlands
Thanks. The tires are the Goodyear Wrangler Workhorse A/T in 245/65/17 with no lift. They fit perfect with no rubbing. I went with the Goodyear's over the Falken's because the Goodyear's were lighter.
Went with the Falken's love em!
Ford Bronco Sport What did you do TO your Bronco Sport today? 1420253972802074990
Trist0n
The Moon
Put on a fordrangerlifts 1.75in lift; worked out great!!! Looks awesome without making the car look stupid lifted, adds a lot of functional clearance, especially on that front lip. Surprised at just how much larger it feels. Still needs an alignment. This is on 235’s
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5153
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5168
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5169
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5171
dustinlane
Dustin
Elkton, Va
2024 Bronco Sport Heritage
Put 245/65R17 on a matching wheel in as my spare. Everything I store in the back still fits, though as others have said I did remove the insulation pad. Not sure about the tire hold-down, will have to check it out further . . . but as tight a fit as the spare is it would take a hell-of-a bump to cause it to
bounce around <lol>. Did this in prep for new 235/70R17’s that are on order; went w/Firestones as the Wrangler AT’s are being discontinued
How do you like the Destinations on the Bronco? I always ran Destination AT 2's on my F-150 and loved them and have been thinking about putting them on my '24 Heritage.
Bill G
San Gabriel Valley, CA
I’ll find out shortly. I only have the spare right now as it’s 245/65R17, the largest size I could fit inside the Sport (still had to remove the insulation padding, and must “fiddle“ with the hold down rod). I’m waiting for delivery of the “on-the-ground” tires which will be 235/70R17’s.
Lynn
Mesa, AZ
2024 Bronco Sport Free Wheeling and 2008 Ford Mustang GT/CS
My plan was to install a rear bumper cover today. I had a feeling it might need to be a little warmer outside and the parts gal had no idea what was required. Opened the box and found the instructions - 68 degrees F. Oh well, I guess I'll be waiting awhile.
I just picked mine up yesterday - doubt AZ will see 68 degrees anytime soon :(
I think that is a minimum temp. I know you are seeing well over 68F every day now.
Trist0n
The Moon
Ford Bronco Sport What did you do TO your Bronco Sport today? VideoCapture_20250414-152259
Installed and enabled factory goodies today. Free with ford points.
Door keypads are underrated, love how seamless these are in the door. Was worried about how it would perform in rain or other harsh weather but it’s never been a problem
Paradocks
Doug
Pittsburgh, PA
2025 Bronco Sport Badlands
B-Dog15
Brandon
Covington, Ky
Took the baby Bronco in because I was getting an odd smell coming through the AC vents. I had also noticed coolant level dropped… I already knew the water pump was the culprit and the service guys confirmed it. I had brought it in a couple months ago when I noticed my coolant level looked low however they could not find signs of a leak and it passed the pressure test. The guy that looked at it did mention that it’s not uncommon for these to pass pressure tests when the leak is super small and told me to check it every once in a while. I appreciated his honesty and advice!
On the bright side it is still under warranty and my dealer said they will only need it for a couple of days to flush the coolant system and put in the new water pump so hoping to have it back by Friday this week. I double checked that they were going to flush the system and they assured me that was already a part of their plan.
I am very fortunate to live close to really good dealer/service department who always seem to do a good job.
dustinlane
Dustin
Elkton, Va
Could you describe the smell?
