1.5L EcoBoost cold weather start up
Dffej49
Jeff
Penneylvania
2024 Bronco Sport
Currently have a 2024 Outer Banks with the 1.5L engine. On cold start up (40 degrees or less) there is a considerable engine tap that lasts until the engine warms up (about 10 minutes) and then quiets down to normal engine sounds. Is this normal?
SN19745
NA
2023 Bronco Sport Big Bend
Mine does not do that. Only revs a little higher at idle like all engines do trying to warm up. Post a video of it if you can
RushMan
Russ
NW NJ
'24 Shadow Black Badlands
That is normal for a direct injection engine. My '17 Escape sounded like this also. It's been variously described as a sewing machine or as diesel clatter.
BSBB4Les
Les
I have a '24 BB and I watch the tach. At initial start-up the rpms are generally just over a thousand, I wait until the r's fall to the normal range of about 800, then I go.
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
the video mentions the ford 3.5 ecoboost cam phaser rattle
however it might be interesting to try a pre-lube flood mode start
if the noise subsides I'd be making an appointment with the dealership
Robink
Robin
Utah
Ford Bronco sport
My 21 BB does it as well.
Dadio
Rob
Cobourg, Ontario
2023 Ford Bronco Sport
The 3 cylinder motor has a “growl” (similar to a small diesel engine), that’s more pronounced when not at full operating temperature. In colder weather , suggest to let it warm up for a few minutes before driving away. In really-really cold weather -15c/ 5F … plug It into the block heater overnight If you have one installed.
The problem with questions like this is perception. One person's "tap" is another's "click." One person's "loud" is another's "noticeable." The only way you're going to get to the bottom of this is to compare yours with another like it. If you take it to a dealership service center they can directly compare it to other vehicles like yours. That'll be the definitive answer you're looking for.
