COVER FOR REAR WINDOW WIRING
wireman
Murrieta
Did a search on here with no luck.
I remember seeing a post about covers for the rear hatch window wiring connections for the heating element.
1 in each upper corner.
I had an issue with the connector bending over and causing 1 coil to get caught between the window and the gasket.
Very hard to see with everything blacked out in that area. Caused a serious water leak into the rear area until I figured it out what was causing it.
Those connectors bend very easily by accidently getting those coiled cords caught on something or when cleaning the inside rear window.
Anyone put these on and have a link so I can purchase them?
I assume yours has not broken like this one?
Ford Bronco Sport COVER FOR REAR WINDOW WIRING 1685646086424
wireman
wireman
Murrieta
Not yet. A piss poor design by Ford. The connector is brass/copper and very fragile.
Should come from the factory with some sort of cover.
I will look on Ebay motors to see if I can find something. The challenge is to figure out what to call it.
wireman
wireman
Murrieta
Ok I found one of links..
Jimen for Ford Bronco 2021-2023, for Ford Bronco Sport 2021-2023, 2PCS Tailgate Rear Window Heater Cable Cover Trim https://a.co/d/6rZ8WBP
wireman
wireman
Murrieta
That Amazon item is $16 less 5% plus tax
looks like it's a little cheaper on Ebay. I prefer Amazon but I ordered it all ready.
Thanks for your effort.
I suggest to everyone to consider these. If you haven't had a problem yet, you probably will.
Ordered mine! Thanks for the heads up.
After you guys have the covers awhile let us know how well they work out for you. The are no real reviews on Amazon for the link I posted and the FB post on the topic was not too helpful either
wireman
wireman
Murrieta
As long as they stay attached to the window, they have to help somewhat.
After seeing how flimsy these connections are, it's just piece of mind for me.
I have no idea how it got bent over and caused the leak. Maybe when I cleaned the inside of the window, not really sure. Just be cautious when working around the connections.
We'll see. Ebay says not arriving till next Wednesday.
JohnSilver
Knoxville
how many do you need to purchase 1 or 2?
Edit: looks like 2
SeaJay
Georgia
2023 OBX Sport, Area 51, Hitch, Assist++
I love the forum for threads like this. Potential problems I can address for pocket change and would have never noticed until the problem occurred to me. So glad people post their lessons hard learned!
wireman
wireman
Murrieta
My covers weren't supposed to arrive till next week. Ordered on Thursday and they arrived today, Saturday. Only 2 days going coast to coast.
They are what the ad shows on Ebay. Looks like 3M tape on the back. An adhesion promotor was also enclosed, but I decided not to use it since the heating element is exposed on the window where these attach.
It probably wouldn't have affected the element, but I
deferred not to use it.
They fit as advertised. See the attached photos.
Ford Bronco Sport COVER FOR REAR WINDOW WIRING 3
Ford Bronco Sport COVER FOR REAR WINDOW WIRING 4
Ford Bronco Sport COVER FOR REAR WINDOW WIRING 5
Ford Bronco Sport COVER FOR REAR WINDOW WIRING 6
davidg4781
Did you use anything to clean it at least? An alcohol wipe or something?
