COVER FOR REAR WINDOW WIRING
PugDad
Bronco Lilly
Newfoundland,Canada
BSBL
Ordered a set as well, this forum is costing me the price of a Baby Bronco’s “baby.”
I see accessories I want / need and well I fold like a cheap dollar bill! Then hit the order button.
Thanks for all the valuable information.
wireman
wireman
Murrieta
Gotta spend our money on something. Might as well be our vehicles.
Mrmike
Syracuse, New York 13219
Good find Wireman! Thank you for this tip and the purchase info. Just ordered for my '23 OBX.
davidg4781
I just washed my BS. When I was wiping down the rear window it looked like the wiring clip wasn’t pushed in all the way.
Sure enough, I was able to push it forward. It the tension on the wire pulled it out just a bit.
My covers should be in tomorrow.
Mine came like that from the factory, pushed once 16 months ago and the connectors haven’t moved
Did you use anything to clean it at least? An alcohol wipe or something?
Post #14, third picture shows adhesion promoter.
Does not surprise me that Ford left off a cover like this, when they leave off under dash covers, engine covers, and hood insulation covers.
But I still like the little guy.
wireman
wireman
Murrieta
I never had an issue with the connection. My concern was how easy the prong on the heating element, where the coiled wire connects, would bend. Bend it to many times and it will surely break off the heating element.
It's very soft metal and I bent it somehow not realizing it. That's how I ended up with the coil catching between the glass and gasket, thus a serious water leak.
Like I stated earlier, these should cost about 10 cents to make. Crazy price for what they are but it will help to keep from doing the same thing again.
Having that connector exposed isn't the best design by Ford. That window opening is fairly small and it's easy to hit them or catch the wire when putting stuff in the back IMO.
Installed mine from Amazon yesterday. Definitely good peace of mind but $15 for a couple of $.10 parts is hard to stomach. They do have to cover the cost of a mold and the labor to put all those little pieces of double sided tape on them. I'm sure this is not a high volume product for them. Just imagine how much Ford would charge for these!
wireman
wireman
Murrieta
We all know where these are made. Yea the middle man makes the profit here for sure. I guess these will fit the full size Bronco also so the connections must be similar.
Ford, probably at least $20.
petegee77
Peter
Buffalo NY
That Amazon item is $16 less 5% plus tax
Just checked Amazon and sadly , as of now, they are sold out. Not sure if they'll get more.
This one is for the Ford Bronco, see if you think it’ll fit the Bronco Sport. It does not say free returns however.
HTHE for Ford Bronco Tailgate Rear Window Heater Cable Cover Antidust Waterproof Cover Compatible with Ford Bronco 2021+ 2/4Doors(2pcs,ABS,Model A) https://a.co/d/2paQUzI
cprcubed
Patrick
Parker, TX
Just put mine on today. I can't believe they just left those exposed like they did. Cheers!
