COVER FOR REAR WINDOW WIRING
Here are pictures of my 2006 Escape and 2022 Bronco. The design is basically identical. These are standard Faston style connectors that have been used for years. Like I said before, my Escape has endured plenty over the past 17 years and these has been the least of my worries.
There are plenty of cases of people putting decals and do-dads land such on their Bronco’s. There’s no reason anyone has to justify their decisions to people.
My main concern and why I appreciate this forum is for learning of issues that help this community. But as an old fart with a few million miles under my butt and many with hatchback and SUV vehicles, this I don’t think is really a failure waiting to happen.
Ford Bronco Sport COVER FOR REAR WINDOW WIRING IMG_2699
Ford Bronco Sport COVER FOR REAR WINDOW WIRING IMG_2698
Barry S.
Barry
Holly Springs NC
It's funny that this same issue came up on the full size forum as well. I've never had one of the connections fail on the rear defroster and none of them have ever been covered before. I realize it's cheap insurance but are many people actually experiencing the connection breaking off?
I have no idea. I do know that I enjoy buying gizmos and gadgets for my BS and this was just another excuse.
wireman
wireman
Murrieta
That connector looks a heck of a lot stronger than what's on the Sport.
As Meanderthal mentioned, if you are using the window opening a lot, chances are you may damage it accidently or not.
They are both basically identical. 3m’s Faston’s or some equivalent. The Escape’s solder job is definitely nicer but that was before the lead free solders. Certainly if someone catches it with taking cargo out it could be damaged. My point I was trying to make was this is the same design used for as long as I can remember and I’ve never had one fail. I’d be more concerned with catching the cable than necessarily hitting the connector but then I golf like crap so hitting things precisely isn’t my strong suit.
wireman
wireman
Murrieta
I can't look at the connector on my sport now with the covers on, but your 2nd photo of the Escape connector shows a "gusset" and it looks somewhat thicker metal compared to the sport. No coil of wire to cause issues on the escape either.
I had to bend the connector back to the correct position and it didn't take much effort to due so.
No argument on what you should or shouldn't do. I just want to keep the turds in the punch bowl to a minimum.
SeaJay
Georgia
Did a search on here with no luck.
I remember seeing a post about covers for the rear hatch window wiring connections for the heating element.
1 in each upper corner.
I had an issue with the connector bending over and causing 1 coil to get caught between the window and the gasket.
Very hard to see with everything blacked out in that area. Caused a serious water leak into the rear area until I figured it out what was causing it.
Those connectors bend very easily by accidently getting those coiled cords caught on something or when cleaning the inside rear window.
Anyone put these on and have a link so I can purchase them?
Well, once you pointed it out I just couldn’t unsee it.
Ford Bronco Sport COVER FOR REAR WINDOW WIRING IMG_3355
Ford Bronco Sport COVER FOR REAR WINDOW WIRING IMG_3354
Kraken23
Allen
St. Louis, Missouri
2022 BS BL
One of mine broke off this weekend. I don’t normally open the glass so it was a bit surprising. It appears that they are just soldered on to the connection at the window. Has anyone resoldered them on and if so did you take the back glass off to make it easier to do?
rocks
SC
rorlow
Ron
Detroit MI
Ordered from Amazon couple days ago, out for delivery now, thanks for the heads up guys!
