I forget what they are called, but they make these butt connectors with low temperature solder inside and heat shrink on the outside. Just put all 3 exposed connectors together and heat the whole thing up with a lighter and you are done.I just received my Tetico side marker kit. I bought the simple 2 wire (black & red) wire kit. I am only going to wire it as an amber turn signal. The problem with this kit is the wire. It is only 18 gauge. I need to tap into the factory wiring with a different gauge of wire (heavier). Does anyone know of a quick connector that will join wires of different gauges? If I have to, I can strip a section of the factory wire, solder the connection and apply liquid electrical tape to the splice. Any other suggestions?
