- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 119
- Messages
- 6,727
- Reaction score
- 13,160
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
Acceleration can be affected by many factors, with power-to-weight ratio one of them. 280 hp at 4,200 lbs is 15 lbs per horsepower. The Bronco Sport is 3,700 lbs, so to match the Passport's power-to-weight ratio your engine needs to produce a bit over 245 hp, which is nearly 30% more than stock.It is definitely faster than our Passport which is a 280hp V6 but it has 4200 pounds to haul around.
To be sure you would have to do some acceleration comparisons between the two vehicles, but if your Bronco Sport is significantly faster than your Passport your engine must be producing significantly more power than stock.
