How much of the car did you cover? I have a few spots I'm considering PPFing.
Nice, I bought the OEM strips for the sills, and they aren't very protective. The rear ones are really short, and the front ones are narrow. They do look nice, though.I installed custom floor mats, cheap but lots of good reviews and fit very well. I have protective strips for the door sills coming.
I dont even bother looking a Fords site for any of this. Cross rails for the roof racks are in the works and OEM are double what Im going to spend.Nice, I bought the OEM strips for the sills, and they aren't very protective. The rear ones are really short, and the front ones are narrow. They do look nice, though.
Yeah, I had 70000 Ford points, so I did some shopping with them. I normally don't use the site.I dont even bother looking a Fords site for any of this. Cross rails for the roof racks are in the works and OEM are double what Im going to spend.
I paid 1/3 of Ford's cost and bought highly rated crossbars elsewhere also.I dont even bother looking a Fords site for any of this. Cross rails for the roof racks are in the works and OEM are double what Im going to spend.
It cant be a 24’ and don’t think theres any 26’ out yet, but i could be wrongDid you lift your bl? What year is it?
Have you considered mounting the Midland at an angle (canted to the rear) instead of vertically? That might alleviate some of your issues.Technically a few months ago, but i installed a Midland MXT575 GRMS Radio in my car, Tried doing it the "temporarily permanent" style most of my work is, and hit the classic problems i create.
I drilled holes in my JCR Offroad side Molle Panels for the Midlands mount and had to use some... physical persuasion to get the radio in the mount because the curve of the glove box was stopping it from sliding down into the mount (this will be a new and exciting problem later). For cable management, I secured the wires near when my under dash lighting is and routed the cables through the door , because, one day, ill finally decide to run something properly through the firewall (btw, the cables were barely long enough for the door route, but again, its not the best wiring decision)
Now, elephant in the room, the mounting location is almost perfect, but, the glove box door hits the radio barely, there is enough play in the molle panel to press in on the radio to open the glove box, so its not a complete issue, but its a minor annoyance. But if you see the scratches on the glove box from the first picture, you can guess im not immediately worried about it.
I'll be honest, if I didn't hate working in the foot well area because of my back, I would probably tried either lowering it to the bottom of the bracket or angling it, but I believe it will always have the contact issue with the glove box opening.Have you considered mounting the Midland at an angle (canted to the rear) instead of vertically? That might alleviate some of your issues.
Side note, how's the fit on the Molle panel? In the pic it looks like it was made for that spot.
