- First Name
- Stoge
- Joined
- Aug 30, 2022
- Threads
- 4
- Messages
- 235
- Reaction score
- 686
- Location
- Florida, USA
- Vehicle(s)
- 2022 Bronco Sport
To keep a long post from clogging the "What did you to TO your bronco sport today" thread, here is what i did Saturday and Sunday to my 2022 Bronco Sport Badlands.
First things first I installed the Skid Plate and Rally Light Bar from Rally Innovations. Skid plate took less then 5 minutes, swapped out four bolts for included bolts with spacers and bolted the plate in. EZ PZ. The Rally light bar took a bit longer, probably an hour total, most of the time was slowly undoing the bolts at the front towhook mount. Not a lot of space and long bolts. Instructions came with pictures and were really easy to follow.
Next i was onto the lights. I had contacted Rally Innovations about if i could fit the Lights i wanted on the bar, they didn't think i could, but after going through the thorough and ample CAD drawings from Diode Dynamics, i decided to go for it anyways. I went with Diode Dynamics SS5 Cross Link 4-Pod in yellow / combo / sport. Additionally i ordered their Heavy Duty Single Output 4-Pin Wiring Harness and two Stage Series SS5 Universal Bracket Kits as i knew their universal Cross link mount wouldn't fit on the Rally Innovations Bar. Setting up the Cross Link bar was a bit time consuming but not awful, kinda tricky because i wasn't the mounts as designed but it seemed to work out, great instructions and full videos on how to set those up. I had to flip the Rally Innovations Light bar and drill new holes for the RivNuts to secure my Lights, all in all probably an additional 2 hours to get assembled and mounted.
Next up was one of my weaker skills, Wiring. I had the deutche connectors from Diode Dynamics so getting the lights together wasn't hard, and with the wiring harness the trickiest part was getting through the engine bay to my wireless relay. I had to pull the trim over radiator to drop the main line down to fish it out at the light bar, not crazy but took a bit of fishing around to pick my path. Unfortunately i can't use my wireless relay yet as I'm waiting for a blasted A23 battery to delivery, but till then i ran the included switch from Diode Dynamics through the door and into the cabin so i can at least have the Backlights and Full Beams functioning till Amazon sends me my batteries. Yes it does take up quite a bit of real-estate on the front camera, No i don't have Radar Guided Cruise Control so i cant tell you if it screws with those sensors. But im a sucker for the old Rally Styling and i couldn't resist having some big lights front and center.
Last on the docket was a new level of hell. I knew it was going to be a PITA install because i watched the video for the install twice, but that 20min video turned into a 10 hour Hell of a time. Would have been significantly shorter if i had anyone else helping me but whats done is done. I installed JCR-Offroads Bronco Sport Roof Rack. With this install done ive successfully completed the set of completely disassembling the front of the car (for Fog Light swap) The back of the car (For installing the Ford trailer Hitch) and removing the roof liner (This). Unfortunately there was not included instructions i remember or could find so all i had was the video. The video was great but what hardware to use where was a significant issue, and i ended up with a surprisingly amount of spares that i dont know what they do or where they go. Also, someone blasted shipping staples through their sticker sheet. Overall, love the way it looks but if i was smart i would have started with this on Saturday instead of waiting till sunday and finishing at 3am.
Now i got to figure out what to do with the factory rails.
