- First Name
- Tomas
- Joined
- Jun 2, 2024
- Threads
- 7
- Messages
- 1,155
- Reaction score
- 1,583
- Location
- Sacramento
- Vehicle(s)
- 2024 Bronco Sport Badlands
@hefler might have to look in other folders and enable there also if listed.
do your side mirrors have the signals built in on the outside as well?
In PTS, when I pull the wiring schematics for my 2023 BS, I get two possibilities for the the way the mirrors are wired: One for vehicles that have one touch up and down that DOES include wiring for the mirrors to fold in and out:Yes, it does have.
I checked the APIM as build it and the APIM normal module
Do you have the latest version of FORScan? If so, I'll be home and settled in in about an hour. I will plug into mine then to see if I see anything different.I will try and post here. Thanks @rugedraw
Update: my Vgate OBD read only those modules:
(OK) [20:47:51.201] Found module: PCM - Powertrain Control Module
(OK) [20:47:51.447] Found module: OBDII - On Board Diagnostic II
(OK) [20:47:51.739] Found module: APIM - Accessory Protocol Interface Module
(OK) [20:47:51.794] Found module: BdyCM - Body Control Module
(OK) [20:47:51.832] Found module: AWD - All Wheel Drive Module
yes, the 2.3.66Do you have the latest version of FORScan? If so, I'll be home and settled in in about an hour. I will plug into mine then to see if I see anything different.
I'll let you know if I see anything different on ours. I have FORScan beta, but I don't think that matters in terms of what modules it can read.yes, the 2.3.66
If I interpret you correctly, it's an either/or with the one-touch windows or power folding mirrors. I'd rather have the one-touch, then, and glad I do. Folding mirrors are never something I'd consider terribly necessary, at least in the 'burbs and beyond. The windows, OTOH, are massively useful.In PTS, when I pull the wiring schematics for my 2023 BS, I get two possibilities for the the way the mirrors are wired: One for vehicles that have one touch up and down that DOES include wiring for the mirrors to fold in and out:
If the motor is in the mirror assembly, there has to be a way to do it. It could be the Maverick config is different from these. We're still working in the dark here. I reached out to Livnitup today and he's still unable to make a spreadsheet for us. I'll check back with him in another month or so.Same here. This is a weird situation. The config is there, and right. The module is there, the option shows at the car configuration (to enable and disable) but when we try.
NOPE
I have a friend here with the same car and year and he can fold. But since he is the second owner he doesn't know what the first owner did it. I guess the used a plug and play module to do that (like the image below)
I don't want to use that solution since I guess the solution already exist in our car
Sorry, I missed this before, but according to the diagram, it's the ones that have both one touch up and down that shows wiring for power fold in and out. That's why I was hopeful it would work. My girl was excited about it, too. Here in the city, it's a nice feature to have.If I interpret you correctly, it's an either/or with the one-touch windows or power folding mirrors. I'd rather have the one-touch, then, and glad I do. Folding mirrors are never something I'd consider terribly necessary, at least in the 'burbs and beyond. The windows, OTOH, are massively useful.
I messed around with it a bit more, but couldn't get it to do anything. I'm not ready to give up on it. Can you message me the VIN of this truck that has it working?I have a friend here with the same car and year and he can fold. But since he is the second owner he doesn't know what the first owner did it. I guess the used a plug and play module to do that (like the image below)
