Bronco ForScan Thread
hefler
Global
Bronco Sport 2023
I have photos showing that is activate but is in portuguese.
Ford Bronco Sport Bronco ForScan Thread Screenshot 2025-08-11 at 10.26.41
Ford Bronco Sport Bronco ForScan Thread Screenshot 2025-08-11 at 10.28.35
hefler
Global
Bronco Sport 2023
@hefler might have to look in other folders and enable there also if listed.
do your side mirrors have the signals built in on the outside as well?
Yes, it does have.
I checked the APIM as build it and the APIM normal module
Ford Bronco Sport Bronco ForScan Thread Screenshot 2025-08-11 at 10.36.58
rugedraw
Javier
Miami, FL
Yes, it does have.
In PTS, when I pull the wiring schematics for my 2023 BS, I get two possibilities for the the way the mirrors are wired: One for vehicles that have one touch up and down that DOES include wiring for the mirrors to fold in and out:
Ford Bronco Sport Bronco ForScan Thread U&D
And another for vehicles with one touch down only that do NOT show anything in terms of wiring that will support power-fold mirrors:
Ford Bronco Sport Bronco ForScan Thread Down only
I am not sure if ours is one touch down only or if it does both up and down; my girl is going to check later when she gets off of work since it's her truck. However, assuming the the hardware is there for power fold mirrors to work, it would also need to be enabled with FORScan in the PDM and DDM for it to work.
Looking through the FORScan spreadsheet for the Maverick, it seems like the door modules are the same as the 2023 BS, I see this in there that looks interesting:
Ford Bronco Sport Bronco ForScan Thread 1754941590418-y
My BS shows a 0 there for disabled in the DDM and PDM.
Ford Bronco Sport Bronco ForScan Thread 1754941619681-8a
Ford Bronco Sport Bronco ForScan Thread 1754941790276-af
You can try changing that value to a one to see if it works.
Edit: Confirmed that our BS does have auto up & down. I'll mess with it later tonight to see what happens.
hefler
Global
Bronco Sport 2023
I will try and post here. Thanks @rugedraw
Update: my Vgate OBD read only those modules:
(OK) [20:47:51.201] Found module: PCM - Powertrain Control Module
(OK) [20:47:51.447] Found module: OBDII - On Board Diagnostic II
(OK) [20:47:51.739] Found module: APIM - Accessory Protocol Interface Module
(OK) [20:47:51.794] Found module: BdyCM - Body Control Module
(OK) [20:47:51.832] Found module: AWD - All Wheel Drive Module
rugedraw
Javier
Miami, FL
Do you have the latest version of FORScan? If so, I'll be home and settled in in about an hour. I will plug into mine then to see if I see anything different.
hefler
Global
Bronco Sport 2023
yes, the 2.3.66
rugedraw
Javier
Miami, FL
yes, the 2.3.66
I'll let you know if I see anything different on ours. I have FORScan beta, but I don't think that matters in terms of what modules it can read.
2025 Badlands Sasquatch
If I interpret you correctly, it's an either/or with the one-touch windows or power folding mirrors. I'd rather have the one-touch, then, and glad I do. Folding mirrors are never something I'd consider terribly necessary, at least in the 'burbs and beyond. The windows, OTOH, are massively useful.
rugedraw
Javier
Miami, FL
Ok, so I can for sure access all the modules. Using my VLinker and not the Mongoose. Give me a bit to play with it.
Ford Bronco Sport Bronco ForScan Thread 1754955029683-ej
rugedraw
Javier
Miami, FL
Well, it was worth a try.
hefler
Global
Bronco Sport 2023
Same here. This is a weird situation. The config is there, and right. The module is there, the option shows at the car configuration (to enable and disable) but when we try.
NOPE
I have a friend here with the same car and year and he can fold. But since he is the second owner he doesn't know what the first owner did it. I guess the used a plug and play module to do that (like the image below)
Ford Bronco Sport Bronco ForScan Thread 1754956200202-g8
I don't want to use that solution since I guess the solution already exist in our car
rugedraw
Javier
Miami, FL
NOPE
If the motor is in the mirror assembly, there has to be a way to do it. It could be the Maverick config is different from these. We're still working in the dark here. I reached out to Livnitup today and he's still unable to make a spreadsheet for us. I'll check back with him in another month or so.
rugedraw
Javier
Miami, FL
Sorry, I missed this before, but according to the diagram, it's the ones that have both one touch up and down that shows wiring for power fold in and out. That's why I was hopeful it would work. My girl was excited about it, too. Here in the city, it's a nice feature to have.
rugedraw
Javier
Miami, FL
I messed around with it a bit more, but couldn't get it to do anything. I'm not ready to give up on it. Can you message me the VIN of this truck that has it working?
