BLUEOVALRACER
Ohio
Not today, but earlier this week. Swapped out the factory steel rims for some gloss black ones. Looks much better.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5639
Looks good i didn't know you could get the steel rims on the Big Bend until i looked in the 2022 Bronco Sport Brochure and it looks like they were an option?
JakeNB
Jake
NB Canada
2024 BS
My mistake- they are actually 17” Carbonized Grey-painted Low Gloss Aluminum Wheel that come with the Black Diamond package. They look like steel winter rims.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5657
Humper
Mick
Oklahoma
Added OEM ambient light in the cubby / charging area and whilst I was in there added another 12v outlet and a 12v display, did not loose any room for phone charging.
Ford Bronco Sport What did you do TO your Bronco Sport today? 1000005183
Ford Bronco Sport What did you do TO your Bronco Sport today? 1000005182
gatornek
Miami
Installed HRG molle panel. Easy install and seems pretty solid
Ford Bronco Sport What did you do TO your Bronco Sport today? moll
How are these holding up?? Still rock solid, even after adding weight? The install is essentially just tapping into the plastic panel behind the liner?? What exactly are the screws tapping?
I think they are a great spot to add extra cargo space for the BS, but I worry, that they'll just fall off after a bit.
EARLSAYS
Earl
Houston
Which wires do you need to splice into to light those up? I have the lamps installed, but my badlands did not come with ANY ambient lighting wiring....I need figure out which wires to tap into.
Horse n Buggy
Stoge
Florida, USA
I'm not Bill but I have these installed on my car. They are secured with 6 self tapping screws, two in the roof liner (they only tap the liner) and two in each of the side plastic trim panels (tapped solely in the plastic trim).
I wouldn't go ham with loading them, but small tools, med bags, flashlights and whatever else feel very secure when mounted. You would have to start hanging hammers on them to get sketchy with the mounting.
Ford Bronco Sport What did you do TO your Bronco Sport today? 1000005015
Ford Bronco Sport What did you do TO your Bronco Sport today? 1000005016
Humper
Mick
Oklahoma
Without having ambient lights installed, there would be no wires to tap into. The cubby light has 3 wires, ground, positive and a data (I think the 3rd wire acts like a potentiometer, reduces or increases voltage?) anyhow the light will work with just a ground and a 12v line, it just won't go from bright to dim. Now having said all that, I wouldn't bother even on the brightest light you can hardly tell it's on.
To light up my cubby I used this.
https://a.co/d/7Pktj5B
I ended up cutting it down to just one of the cuttable sections, just around an inch, sticking it to the top of the cubby and it lights the whole area up nicely, I cannot see the strip light from my driving position and there is no reflection of the led in my phone screen when it's on charge, it's just a nice glow, doesn't match the cup holder lights perfectly but it's close enough.
I positioned the led about 1/4" down and centre from the front of the under panel, I also warmed the end of the cable up and bent the wires coming off the led strip towards the USB plug.
Bill G
San Gabriel Valley, CA
It’s been on for a while now and have no complaint. As others stating — don’t over-load it, screws are just in the plastic trim, but it fits snugly and seemingly will hold light/moderate weight. Seems to me that the pulling forces are horizontal, not vertical.
TNFurb
Nashville
I installed PPF on my headlights, roof area just above the windshield, and the a-pillars. The headlights were a little tricky dealing with the curve on the outside edges. And it would have been helpful to have a second pair of hands on the roof, but overall it was relatively simple. the key is patience. I already had film on my hood, bumper and front fenders that I paid to have done right after purchase. Doing these areas myself saved a good amount of money. Links to the film I bought are below.
https://www.ebay.com/itm/133889740570
https://www.ebay.com/itm/144223097662
Myrtle Beach
2024 Bronco Sport
One of the things that bugged me a bit was that Ford chose to equip my Badlands with LED lighting everywhere BUT the taillight turn signals, brake lights, and backup lights. So today I took care of that and changed out the bulbs with LEDs:
Ford Bronco Sport What did you do TO your Bronco Sport today? 20210123_103454(0)_tonemapped
For those are interested, the LED Bulb types you'll need are as follows:
Turn - 921 Amber
Brake - 3157 Red
Backup - 7443 White
Installation was a snap. Changing out the bulbs is well documented in the owner's manual but all you need is a 10mm nut driver or socket wrench. Always be careful when working the housing tabs off of the studs (you REALLY don't want to break one of those) but the whole change-out took me less than 15 minutes.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20210123_102405_tonemapped
I used bulbs from Diode Dynamics (www.diodedynamics.com) as they are an American based company and the quality of their products as well as customer support are outstanding (3 year warranty, but I've had them in my Fiesta ST for nearly 6 years now without a failure). But for those on a budget there are admittedly less expensive options out there.
While it's hard to see in the daylight pic, the backup LEDs are probably the biggest improvement in the cars I've put them in, with a noticeably brighter and whiter light than stock.
is this all plug and play with the LED bulbs?
