Nice pic of the 2 door wildtrack and its gauges. We would have to purchase an aftermarket device and plug into the OBD port but wouldn’t be as cool as in the 2 door wildtrack.See post. Thanks
Looks great, Dan!Installed a new Inno rooftop carrier for my camping gear. Love it!![]()
Gotta ask. Where did you find THOSE seat belt cover pads? We have a set that only has BRONCO in big white letters. Like yours MUCH better!Leather cup holders, console pad, seat belt cover, and roof rack cross bars.
I got them on ETSY and asked if they could put Sport under the Bronco.Gotta ask. Where did you find THOSE seat belt cover pads? We have a set that only has BRONCO in big white letters. Like yours MUCH better!
Thanks for the comeback. Just might hafta look into that. ?I got them on ETSY and asked if they could put Sport under the Bronco.
Looks good i didn't know you could get the steel rims on the Big Bend until i looked in the 2022 Bronco Sport Brochure and it looks like they were an option?Not today, but earlier this week. Swapped out the factory steel rims for some gloss black ones. Looks much better.![]()
My mistake- they are actually 17” Carbonized Grey-painted Low Gloss Aluminum Wheel that come with the Black Diamond package. They look like steel winter rims.Looks good i didn't know you could get the steel rims on the Big Bend until i looked in the 2022 Bronco Sport Brochure and it looks like they were an option?
How are these holding up?? Still rock solid, even after adding weight? The install is essentially just tapping into the plastic panel behind the liner?? What exactly are the screws tapping?Installed HRG molle panel. Easy install and seems pretty solid
Which wires do you need to splice into to light those up? I have the lamps installed, but my badlands did not come with ANY ambient lighting wiring....I need figure out which wires to tap into.Added OEM ambient light in the cubby / charging area and whilst I was in there added another 12v outlet and a 12v display, did not loose any room for phone charging.![]()
I'm not Bill but I have these installed on my car. They are secured with 6 self tapping screws, two in the roof liner (they only tap the liner) and two in each of the side plastic trim panels (tapped solely in the plastic trim).How are these holding up?? Still rock solid, even after adding weight? The install is essentially just tapping into the plastic panel behind the liner?? What exactly are the screws tapping?
I think they are a great spot to add extra cargo space for the BS, but I worry, that they'll just fall off after a bit.
