Bronco ForScan Thread
xm41907
James
Baltimore
DISCO! Was able to achieve only the Speed Limit sign to show on dash on my BS Big Bend without having the Assits360+ or whatever it’s called package.
It does leave a line under the compass reading/heading but that’s tolerable.
Ford Bronco Sport Bronco ForScan Thread IMG_4709
Ford Bronco Sport Bronco ForScan Thread IMG_4712
Ford Bronco Sport Bronco ForScan Thread IMG_4711
What settings did you change to achieve this? I've got a Badlands without 360+ but would like the speed limit display if possible.
JKauf55
Jason
Tennessee
Ford Bronco
Was able to achieve it by enabling Traffic Sign Recognition in the IPC Module, IPMA Module, and APMI Module - although not sure if this last one was necessary as it didn’t put the menu/option to turn it On/Off on the display under Settings/Driver Assist.
xm41907
James
Baltimore
Hmm. I don't have those modules in my forscan. It looks like i might need a different adapter.
Ford Bronco Sport Bronco ForScan Thread 17044258435455123762649626348427
Ford Bronco Sport Bronco ForScan Thread 17044258589308183448979559584737
kshaw
Kent
Gaithersburg, MD
I saw on YouTube that ForScan can add a temperature over the temperature gauge on some Fords. Anyone tried that on the BS? It would be great to display gallons over the fuel display.
rob28
Rob
2022 Bronco Sport, 2023 F-150 Tremor
Hi, we just picked up a 2022 Outer Banks yesterday and the door entry code is missing. Can this be found using Forscan?
Also, has anyone made a spreadsheet or quick reference for the common changes on the Bronco Sport. I know there's a really good spreadsheet available for the F-150 but I haven't seen one for the BS yet.
Door code is a pretty often posted topic, here is one link:
https://www.broncosportforum.com/forum/threads/door-code-retrieval.10478/
There is no FORScan spreadsheet or quick ref for the Bronco Sport that I have seen. The post you are in seems to be about the best info but often times the specific FORScan updates and steps to make are not clearly stated. Some are a trial and error unless you have the experience.
kshaw
Kent
Gaithersburg, MD
I am trying to map the AS-Built lines for the BS to the respective modules. I have 3 addresses that I cannot map: 703,723. and 736. Anyone know what those are?
Wolf256
Jane
Kingston, WA
2023 Bronco Sport Atlas Blue
I’m trying to find a Forscan tool. Would be interested it which one any of you are using and where you purchased it.
ETA: my laptop is Apple, so I need a device compatible to iOS. Any assistance is appreciated.
Wolf256
Jane
Kingston, WA
Amazon
https://a.co/d/45L9OOo
Use with your own Windows laptop
For various reasons a Bluetooth FORScan adaptor can be detrimental
Thank you. I need to go back and adjust my post. My laptop is iOS. ?‍♀ The device in the link is for Windows. I’m looking at the comparable ones that include iOS. Thanks again.
@Wolf256 According to the links below… you need an ELM327 device successfully connected to your PC operating under Windows 2000/XP/Vista/7.
The only version that will allow you to make changes is the Windows version with an extended license. The IOS and Android versions are Lite versions and only allow checking and clearing codes and veiwing parameters.
The answer is here
https://forscan.org/documentation_13.html
http://forscan.org/
Wolf256
Jane
Kingston, WA
Interesting. My local dealership’s Service Department uses iPad tablets in the service bay. They must have a work around. Guess I’ll hold off a little longer.
Yep but those people aren’t using FORScan on those iPADs
PPR_Ricky
Ricardo
Puerto Rico
Does someone know if the temp of the module inside the PTU can be changed? I do some off-roading and if I go to really loose ground the awd system goes off “disable”, turn off and turn on again and I can continue but sometimes I have to turn off and on like 4 times in the same slope.
Winds of Change
Chicagoland
I would think that may cause irreversable damage. Are you doing that aggresive of off roading? I had A BSBL that I was hard on it without issue. I know a Badlands is different than a Big Bend.
