Ordered these the other day and get a new email every day offering me a higher discount even though I already ordered them.
In case anyone is shopping..
40% off - PNGTec
30% off - 3WVTEC
I could not get either of these to work on Amazon. Are these for use on Amazon?
Elegance
Kris
40% off - PNGTec
30% off - 3WVTEC
Thank you for these. A heads up for others looking to use them - 40% off removes free shipping and adds $8. 30% off does not remove free shipping and actually winds up being a few bucks cheaper. 🙂
Elegance
Kris
Wabarca2
Wabarca2
Walter
That's nice. I wish those were around when I did my vents last year. I had to build mine from scratch. They do not interact with the blinkers, they just come on when the lights come on.
Ford Bronco Sport Tectico LED fender light side marker install IMG_20210422_041701968
Ford Bronco Sport Tectico LED fender light side marker install IMG_20210501_152631490
Ford Bronco Sport Tectico LED fender light side marker install IMG_20210527_034656067
Ford Bronco Sport Tectico LED fender light side marker install IMG_20210529_024850558
I like the blue of yours
kyle_conrad
Kyle
Richmond, VA
kyleconrad.com
2022 Bronco Sport Outer Banks
I'll note that my lights from them came with the left one not working with amber - white worked, but not amber, no matter what I did. Contacting their support was not super helpful, as they just kept directing me to connect the wires that I had already connected. No offer for a return or single replacement at any point before I gave up.
Cheaper through them, but the Amazon convenience of being able to easily return them if one doesn't work is kind of nice - the DZG ones I ordered on Amazon came in the exact same packaging as the Tectico ones, same instructions, so they're all identical. This time, the DZG ones worked white and amber on both sides successfully.
Zeker
Keith
Kanata, Ont, Canada
22 Bronco Sport
I installed the side marker install from Tectico today, it was a easy install 3 wires install and that's it. Red wire down to the courtesy side marker, to the blue wire. The yellow wire to the turn signal blue with green wire driver and yellow with purple passenger. Then just the a ground wire on both sides and that's it. They look good and well built
Ford Bronco Sport Tectico LED fender light side marker install 20220717_100611
Ford Bronco Sport Tectico LED fender light side marker install 20220717_101004
Ford Bronco Sport Tectico LED fender light side marker install 20220717_101210
Ford Bronco Sport Tectico LED fender light side marker install 20220717_102928
Ford Bronco Sport Tectico LED fender light side marker install 20220717_102953
Ford Bronco Sport Tectico LED fender light side marker install 20220717_110019
I tried what you suggested Walter. Impossible to get to. I don’t know how you did it. There must be a DRL wire into the headlamp box because there is a running light there. I’ve tried the multimeter to read other wires. It’s only a 7 volt reading and then when I turn DRLs off the reading remains on meter even after all other courtesy lights turn off.
Wabarca2
Wabarca2
Walter
It is a tight squeeze, it's easier with the tire off
PhinG
TX
I installed the Tectico side lights today and they both work fine. I got the ones on Amazon that come with the wiring harness that plugs into the fender lamps. Popping the plug off the back of the lamp was a pain in the rear. It is an awkward angle and you can't really see what you are doing, especially on the driver's side. On the passenger side, between the foam and washer fluid reservoir, it was hard to get some pliers in position to help release the clips to remove the trim.
Overall, though, I do like the wiring harness, and once I got the plug released, it was a super easy, plug-and-play install.
Ford Bronco Sport Tectico LED fender light side marker install 20220929_172348sm
Ford Bronco Sport Tectico LED fender light side marker install 20220929_185705sm
Wabarca2
Wabarca2
Walter
Do they blink withr the turn signal?
PhinG
TX
No, they are only really on when the full headlights are on. The title on Amazon is misleading. You could splice them to the blinkers (which is I guess why they can technically say what they do), but the plug-and-play part does not. It just mirrors the amber lights on the bumper.
WildFord
Los Angeles
'22 BS BL
is this the one?
https://www.amazon.com/TECTICO-Blinker-Warning-Accessories-Badlands/dp/B0BBF1FJRL/ref=sr_1_15?crid=G8O4VPPTPHFP&keywords=bronco+sport+fender+light&qid=1664543879&sprefix=bronco+sport+fender+light,aps,143&sr=8-15&ufe=app_do:amzn1.fos.18ed3cb5-28d5-4975-8bc7-93deae8f9840
I think my wait is slowly paying off. I was hoping somebody will come up with one that will function as side marker as well as turn signal with plug-n-play installation. this is one step closer.
they need to make a plug so we don't need to splice in factory wires.
I think this piece almost was designed for after market mod. that factory "vent" piece is decoration only.
Big Kahuna
William
Oakhurst
theshockleys.com
2021 Bronco Sport Badlands, 2014 Ford F350 Lariat
I think my wait is slowly paying off. I was hoping somebody will come up with one that will function as side marker as well as turn signal with plug-n-play installation. this is one step closer. .
I to was waiting for a plug-n-play option, I'm not too interested in the side marker aspect, so this looks good. Price is a bit steep, I'll keep an eye on it to see if the price drops.
WildFord
Los Angeles
'22 BS BL
if you want turn signal function, just like I do, this light available now thru Amazon is not what we want. it will only function as side marker if you use their plug-n-play setup.
PhinG
TX
is this the one?
Yes, that is the one I got.
@Big Kahuna, when I bought it on Amazon, it was $10 less and there was a $10 coupon, making it $40. I guess just keep an eye on it. The WinPower one, which looks exactly the same except without plug-and-play, is $30.
