- First Name
- Albini
- Joined
- Aug 21, 2022
- Threads
- 1
- Messages
- 15
- Reaction score
- 18
- Location
- Bouctouche, nb
- Vehicle(s)
- 2022 Ford BRONCO SPORT
Amazon Canada $217.00 Canadian dollars and $180.00 at Ford dealership to install.Nice.
Where did you get them?
-Keith.
Amazon Canada $217.00 plus $180.00 to have them installed at Ford dealership. Canadian dollarsNice.
-Keith.
Just a suggestion. You may want to ask your dealer to switch sides they are mounted to. If someone were to hook up a short bridle you want the inside edges back to back not opposite like they are mounted. Looks like they could have done it that way but just made a mistake when they mounted them.Installed tow hooks on BRONCO SPORT BIG BEND.
Looking around on Amazon, the only ones that I can find that look like your pictures are:Amazon Canada $217.00 plus $180.00 to have them installed at Ford dealership. Canadian dollars
Yes,they are the same. I painted them FLAT BLACK.Looking around on Amazon, the only ones that I can find that look like your pictures are:
https://smile.amazon.com/Rough-Country-Forged-2015-2019-Cherokee/dp/B08D9RCTB8/ref=sr_1_23?crid=287L2M5NNZUD8&keywords=bronco+sport+big+bend+tow+hooks&qid=1663528065&sprefix=,aps,68&sr=8-23
Amazon claims that these will not fit the Bronco Sport.
Are these the ones that you purchased and installed?
Thanks,
-Keith.
Just curious, did your BS BB have pre-existing mounting holes?Yes,they are the same. I painted them FLAT BLACK.
I have a 1.5 in lift and 245/65/17 tires so now I have a 10 in clearance. Unless I hit rocks, I should be OK.Do you think they might hit approaching a climb hill? I want to put some on mine as well would just be worried about that.
Nice
Existing hole front bolt, drilled hole for back boltJust curious, did your BS BB have pre-existing mounting holes?
Looks nice. Curious if you couldn't have punched out the plastic tabs in the bumper where the Badlands tow hooks go? Looks like you could have.Installed tow hooks on BRONCO SPORT BIG BEND.
No,at Ford we got the Badland hooks, took the bumper off, and they don't fit on this Big Bend.Looks nice. Curious if you couldn't have punched out the plastic tabs in the bumper where the Badlands tow hooks go? Looks like you could have.
The lower trims are missing a steel bracket welded to the frame that the badlands threaded end connects to. So the factory welds that bracket to the frame on the badlands but ford decided to save a few pennies and not included it to the frames of the lower trims.No,at Ford we got the Badland hooks, took the bumper off, and they don't fit on this Big Bend.
