Tow hooks installed
Chadwick
Keith
Chicago, IL
Nice.
Where did you get them?
-Keith.
Ford Bronco Sport Tow hooks installed 20220912_085940
Ford Bronco Sport Tow hooks installed 20220916_084108
Ford Bronco Sport Tow hooks installed 20220912_131529
Installed tow hooks on BRONCO SPORT BIG BEND.
Just a suggestion. You may want to ask your dealer to switch sides they are mounted to. If someone were to hook up a short bridle you want the inside edges back to back not opposite like they are mounted. Looks like they could have done it that way but just made a mistake when they mounted them.
Chadwick
Keith
Chicago, IL
Amazon Canada $217.00 plus $180.00 to have them installed at Ford dealership. Canadian dollars
Looking around on Amazon, the only ones that I can find that look like your pictures are:
https://smile.amazon.com/Rough-Country-Forged-2015-2019-Cherokee/dp/B08D9RCTB8/ref=sr_1_23?crid=287L2M5NNZUD8&keywords=bronco+sport+big+bend+tow+hooks&qid=1663528065&sprefix=,aps,68&sr=8-23
Amazon claims that these will not fit the Bronco Sport.
Are these the ones that you purchased and installed?
Thanks,
-Keith.
Albini
Bouctouche, nb
2022 Ford BRONCO SPORT
ttt123
brian
Lapeer mi.
2022 ford bronco
Do you think they might hit approaching a climb hill? I want to put some on mine as well would just be worried about that.
Nice :thumbsup:
Albini
Bouctouche, nb
Nice :thumbsup:
I have a 1.5 in lift and 245/65/17 tires so now I have a 10 in clearance. Unless I hit rocks, I should be OK.
delm
Atlanta
Looks nice. Curious if you couldn't have punched out the plastic tabs in the bumper where the Badlands tow hooks go? Looks like you could have.
Albini
Bouctouche, nb
No,at Ford we got the Badland hooks, took the bumper off, and they don't fit on this Big Bend.
The lower trims are missing a steel bracket welded to the frame that the badlands threaded end connects to. So the factory welds that bracket to the frame on the badlands but ford decided to save a few pennies and not included it to the frames of the lower trims.
You can bolt the badlands tow hooks to the bumper support if you want the look but they wouldn't have any strength without the rear frame bracket.
