Oil catch can
TheDude
Tampa, FL
2025 Bronco Sport Badlands with Sasquatch Package
I have one on mine. Have one on the Mustang too. The Bronco collects way more, but expected being a turbo. Even if not really needed I know it collects oil so I'm happy with it.
fourthgear
florida
Seems same theory as on the Sprinter Forum , but no one to date has shown an engine with scientific laboratory results with & with out a Catch can & in the Sprinter Forum they are talking about Turbo Diesel engines & not Gas.. Same moments almost to a "T" .
Its your engine do what ever makes you feel better .
I did this, JLT 3.0... Actually, Ford already has an oil separator on the 1.5L. In the second pic, coming off the left side of the JLT can, follow that hose to where it connects (2 green tabs), that container is Ford's oil separator. So we're getting double protection right, ;).
Ford's oil separator dumping it back into the oil pan, maybe, I don't know? My JLT can is about half full at about 1500 miles. I have to remember to empty it...
Dumping it back in the oil pan is sound science. Crank case venting allows the water to harmlessly burn off.
I do not see the need for redundancy with this system.
I have ran several engines up near and past 500,000 miles without this addition and never had an engine related problem.
Part of a motor oil's job is holding contaminants in suspension. The recommended service interval ensures you change the oil before there are enough contaminants to harm the engine.
baja_bob
Bob
michigan
21 Bronco Sport
Ha , never had one in the first place and don’t feel like fighting with the catch can to possibly being covered by said engine cover. I’m not putting one on.
Hey, I'm just kidding you, the engine cover won't interfere with the catch can because it sits just outside of it. I also have the JLT but I want to replace the phillips screws for the cap to a allen screw.
dejones64
Dan
MN
Lancer, BS BB
I honestly didn't know the BS had an oil separator, until it came up in a recall notice. This was after I installed the JLT. It was my assumption that the separator drained back into the pan which makes sense. I'll continue to run with the JLT, I don't think it'll hurt anything, as long as I remember to dump it.
baja_bob
Bob
michigan
21 Bronco Sport
Where is the factory oil separator on the 1.5L?
This is kind of technical in some spots and he glosses over some of the basic functioning of an internal combustion engine. If you don’t understand that, then this might be over your head. I believe it is worth watching to understand why Direct Injection engines will have issues with dirty/cruddy intake valves over time. A catch can is one of the things discussed as a preventative measure but also the NOACK engine oil test. These are both things I am aware of having spent a decade with DI engines.
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
good info
oil volatility
bronco/video/bookmarked
