- First Name
- Tomas
- Joined
- Jun 2, 2024
- Threads
- 7
- Messages
- 1,057
- Reaction score
- 1,387
- Location
- Sacramento
- Vehicle(s)
- 2024 Bronco Sport Badlands
the pictures of his current set up show 225 series continentalsThat’s what Garth has.![]()
Those aren’t continentals.the pictures of his current set up show 225 series continentals
you're right. i was looking too hard at the measuring tape. didn't notice the sidewall on the tires changed before and after as well.You wrote a short story, and didn’t include any photos?I'll post an update if there are any issues with the alignment, but I'm crossing my fingers (and toes!).
https://eibach.com/product/5.81315KThis is a good very descriptive post, I see HRG also offer camber bolts which might be a good thing to have before the alignment.
The shop that installed mine said they couldnt source any and I should rotate the tires every oil change or sooner and keep an eye for uneven wear.
Thanks, I might pick some up. I would have thought if there was an issue Bilstein would have mentioned it or even included some.
Nah, camber bolts are a typical requirement for lifted suspension. HRG’s 1.5” kit includes them, and we sell them all the time at the NAPA I run, but I decided to outsource the ones for the bronco lolThanks, I might pick some up. I would have thought if there was an issue Bilstein would have mentioned it or even included some.
Post it here, too.Bad luck here with the b8 I will create a post to explain my issue but was a factory problem .
It looks like your swaybar link is bentBad luck here with the b8 I will create a post to explain my issue but was a factory problem .
