Sasquatch Tire - fit in trunk?
Mt Goat
Mt Goat
Rick
2025 Badlands Sasquatch
The bottom picture is the front left replacement tire from Walmart with a look at the tread. The middle pic is the rear left original tire lettering showing. The top picture is the front left replacement with the lettering showing. You can see they are exactly the same tire.
Ford Bronco Sport Sasquatch Tire - fit in trunk? Rear left
Ford Bronco Sport Sasquatch Tire - fit in trunk? Front left side
Ford Bronco Sport Sasquatch Tire - fit in trunk? Front Left
Thank you Robert!
Mt Goat
Mt Goat
Rick
Now that we've got that settled - has anyone stuffed that tire into the spare tire space????
Unicorn
Chester
W. WA
BS Badlands with Sasquatch.
The 225/65-R17 Pirreli spare on mine is a tight fit in the spare tire area. I don't think there'd be enough room for a 235/65 since it's about a half inch larger in diameter. I do want to remove a wheel now and find out for sure though. Maybe a weekend project or if/when I get around to searching behind the wheel wells for the aux wiring.
Mt Goat
Mt Goat
Rick
We would love to hear from someone who has tried this. I believe you need to take out the carpet and may need to trim the foam blocks. People have put a 245/65 KO2 in there. I would try it on mine, but I am on the injured reserve list and unable to do that for the time being........
Bill G
San Gabriel Valley, CA
Again, I put a 245/65 Firestone Deatination AT2 on a “steelie” when in my ‘21 BL. I had to remove the insulation; the foam trim didn’t need trimming, but unless I dropped the air pressure (25-26 psi worked) the thing dropped in and wedged itself tight against the sheet metal . . . making it impossible to get out. With the lower pressure you can get it out, though it’s tough for an old man and I carry an air pump to reinflate to 33 psi if I need to use the spare.
Seems like atleast for the 21-24, the 235/65-17’s fit without any modifications to foam or air pressure.
Unicorn
Chester
W. WA
I'm kind of sitting next to you. I was violently ill this week and I was puking hard enough to pull a couple ab muscles. And even my diaphram was a bit sore. Worst I've ever experienced. And getting old just sucks too.
WildFord
Los Angeles
'22 BS BL
well, I just found out 245/65 17 doesn't go into the truck, neatly....I got some new Kumho Roadventure AT52 and decided to start a 5 tire rotation.
The tire went in with 12 psi....but sticking up almost an inch. I haven't got time to investigate how much insulation I would have to remove to fit the tire in. guess I should of read in more detail. before I decided to do that, a quick search on the forum showed the 245 would fit.
and for 235's, that will fit my '22 Badlands without modification. that's what I had in there.
Jmuns
2022 Bronco Sport BL
Do you have a MY25 now too? Post some pics of what’s happening with the tire.
WildFord
Los Angeles
'22 BS BL
no, still have the '22. I can get some pics later of the trunk to let people see what is "not fit".
Ok..finally got some pictures.
First the photo of the trunk spare tire cover with the 245/65/17 sticking up with tire well insulation left in place
Ford Bronco Sport Sasquatch Tire - fit in trunk? 1750476358432-59
tire reduce to about 12 psi to go into well like this...
Ford Bronco Sport Sasquatch Tire - fit in trunk? 1750476480278-3
then I removed the insulation liner, the spare went into well easily (still at 12 psi)
Ford Bronco Sport Sasquatch Tire - fit in trunk? 1750476639366-jn
I ended putting some sound deadening mats at the bottom of the well and it fits fine with the cover goes over just like the 235/65/17. I should of try to air to proper pressure....but I didn't.
Bill G
My experience is that the foam trays can be left in place, they really don’t interfere. If you fill the tire to 33psi you’ll never get it out — it wedges itself against the sides of the well and you’d need a winch to free it. It’ll work at about 20-25 psi.
WildFord
Los Angeles
'22 BS BL
thanks. yes, the foam trays went back in. so 20 psi is about max is your experience. guess I can just leave it at 12 for now. I can always carry a tire pump with me.
No kiding about needing winch to bring the tire out. as is already pretty heavy. I can see if it is wedged in at 30+ psi....I may need a engine hoist to take it out.
incavulator
Hitting this thread with the paddles to bring it back to life, along with providing some additional info in case it helps anyone.
To echo what Bill G and WildFord have found, here is a pic of a 21 BS BL with a brand new 245/65/17 Wildpeak AT4W installed on a factory wheel at 12psi. You can just see the tire peeking out. I think I can live with this, and after I get my normal assortment of "gear" back in there on top of the cargo floor cover, I suspect it will be even less noticeable. This is also with the insulation still in place. If I put just a small amount of weight on the rear edge of the cargo floor cover, I can encourage it to go down all the way. Without lowering the tire pressure, I couldn't get the tire to drop down far enough into the well for it to be acceptable to me. I'm looking at buying a used (but new - never mounted) 245/65/17 as a spare to put on the factory spare wheel so I don't have any issues with the AWD/4WD system if ever have to use the spare, and I in addition to wanting the same size, I wanted something a little more "all terrain" than the factory 225/65/17 Pirelli Scorpion that came in there. I suspect that Scorpion would have been just fine, but it's not very expensive to try to match the tire size and have something with a more aggressive tread pattern. Now, to find a portable compressor in case I need to air up the spare!
Ford Bronco Sport Sasquatch Tire - fit in trunk? 20251221_082059
