Sasquatch Tire - fit in trunk?
Mt Goat
Mt Goat
Rick
2025 Badlands Sasquatch
I'll say this. Had my 2025 BL Sasquatch less than a month and got a flat. Had to order the replacement tire cause not even the Ford dealership here carries them. Walmart was by farrrrrrr the best price. Had them delivered to my home and put on at a Mavis. Had to drive on the spare for 4 days until my new one came in. Absolutely no adverse driving issues on the spare. On the road you don't even notice it. Unless you just reek of OCD and have to have everything matching...the full size spare (which on mine is the stock Scorpions that normally come on the BLs) is more than adequate for a few days driving if you can't find a replacement immediately.
Robert - do you have a link for the tire you ordered from Walmart? I can't find it on their website. They only list the wrangler one, not the OEM one for the Sasquatch. Or did you go to their tire shop and they were able to order it for you? Thanks :)
It should be listed as Wrangler Territory RT
Ford Bronco Sport Sasquatch Tire - fit in trunk? IMG_1295
Discount tire has it as well for basically the same price.
Ford Bronco Sport Sasquatch Tire - fit in trunk? IMG_1296
Mt Goat
Mt Goat
Rick
If you want the scoop on the 2025 tire for the Bronco Sport Sasquatch call the Goodyear factory in Napanee, Ontario, Canada where the tire is made. Talk with the purchasing department which was responsible for working with Ford to specify the OE tire used on the MY 2025 Bronco Sports and Mavericks. Like I did.
I also went to the parts department at a local Ford dealership which would need to be able to obtain the correct tire for the 2025 Sasquatch however at the time (a couple months ago) they did not have the tires without Wrangker on the sidewall.
I guess we went through this a few months ago didn’t we? The non “wrangler” Territory RT still isn’t on any websites I could find.
The_Jimmer
Georgia
2025 Badlands Sasquatch / Desert Sand
We did go thru this …. but of course the topic on this thread is will the Goodyear Territory RT 235/65R17 used on the 2025 Sasquatch fit in the spare tire wheel well
I had an interest awhile ago in locating and potentially purchasing the Goodyear Territory RT used on the 2025 Sasquatch to replace the OE Pirelli tires on my ‘22 BL
Reason included tire weight. Here is a comparison:
OEM Pirelli 225/65R17 (‘21-‘24)
Tire weight (lbs) 25.22
Falken Wildpeak AT3w OEM (‘21-‘24 optional tire), OEM part# 59000690
235/65R17
Tire weight (lbs) 31
FALKEN WILDPEAK A/T4W, Item number 28841790, 235/65R17
Tire weight (lbs) 38.2
used on the 2025 Sasquatch:
Goodyear Territory RT All Terrain 235 65 R17 104T, (M+S Mud & Snow)
Part # (aka Product Code): 710004933
Tire weight (lbs) 29.5
I did get pics of the tire on the 2025 Sasquatch I test drove and posted the specs for the tire at the link provided earlier.
The_Jimmer
Georgia
I know you posted earlier that the replacement Wrangler tire from Walmart doesn’t match the Territory R/T which came with your Sasquatch … is the tread pattern the same on the replacement Wrangler and on the Territory R/T ?
That's not what I said. The tire from Walmart is an exact replacement. The full sized spare that came with mine is a Pirelli Scorpion, which is what came stock on my 2023 BL that I traded for my 2025. The Scorpion rides perfectly as a spare tire if you have to use it for a few days, even though it's not an exact match for the Territory. Don't let the generic picture on the Walmart advert throw you.
The_Jimmer
Georgia
The picture on the Walmart ad (and everywhere else) is the point of what people post about as to its difference to the ‘25 Sasquatch Territory R/T and the Wrangler tire shown in the pic (also was available at the dealership I went to)
just to be clear .. does your replacement tire from Walmart say Wrangler on the sidewall? Not going to ask you to look at both sides of the tire just the side facing you.
And if you are willing to look at your Walmart receipt, is the tire part number 710004933 ?
The bottom picture is the front left replacement tire from Walmart with a look at the tread. The middle pic is the rear left original tire lettering showing. The top picture is the front left replacement with the lettering showing. You can see they are exactly the same tire.
Ford Bronco Sport Sasquatch Tire - fit in trunk? Rear left
Ford Bronco Sport Sasquatch Tire - fit in trunk? Front left side
Ford Bronco Sport Sasquatch Tire - fit in trunk? Front Left
They sure are and thank you for confirming the 2025 Sasquatch tires are available !!
And I did confirm on Walmarts website, the Goodyear tire part number “710004933” is the part number for the Territory R/T tire (even though the website shows the Wrangler version which is now incorrect as it’s the Territory R/T)
Goodyear simply dropped the word Wrangler from both sides of the sidewall and this tire is used on the 2025 Bronco Sport Sasquatch.
The pic isn't incorrect. They just use one image for all sizes like almost all sites do. Pic stays the same regardless of the size. As the rest of the sizes probably have Wrangler on them it's more appropriate to have that image. Same as the Big Bronco and the tires they used for SAS packages prior to MY25. Wrangler was eliminated from the branding of the tire for Ford OEM production in that size.
That’s not exactly correct. Goodyear made a running change on the part number 710004933 tire. This tire used to say Wrangler Territory R/T just as shown on various websites if you look up that part number. The tire under that part number used on the ‘25 Sasquatch and now available at Walmart (probably other retailers) no longer shows Wrangler on the sidewalls
and I physically saw the prior generation tire in the Sasquatch size, 235 65R17 with the word Wrangler on both sides of the sidewall so the tire in that size under the same part # previously used Wrangler on the sidewall and now the tire does not
this running change to the name on the sidewall was confirmed by the purchasing department at the Goodyear Napanee factory in Ontario, Canada - I called them a couple months ago
https://www.broncosportforum.com/forum/threads/2025-my-bronco-sport-goodyear-tires.14109/post-230964
Which part isn't correct? I said they use that photo because that tire in all other sizes will still say Wrangler on it, so they use a photo that is representative of 99% of sizes for that tire, not the 1 size that is OEM for Ford that they took the Wrangler branding off.
Read my updated post not the one you quoted .. I added a paragraph
In this case the 235 65R17 previously did come with Wrangler on the sidewalls and now the same part # tire in the same size does not show Wrangler
As stated I confirmed that running change with the Goodyear factory and I physically saw the tires in the 235 65R17 size with Wrangler on the sidewalls for part # 710004933
