daShadow
Vern
Western WA
2024 Bronco Sport
Got this today from Amazon for $15, it has the ring around the neck so it hangs there while filling up.
Ford Bronco Sport What did you do TO your Bronco Sport today? 50
To each his own but I don't understand the need for that piece. It's so convenient not having a cap anymore. Millions of vehicles are on the road with no cover and with no issues.
daShadow
Vern
Western WA
2024 Bronco Sport
As you said, "to each his own" and there is obviously no real need for that piece. Is your BS exactly as from the factory or have you added anything that wasn't absolutely necessary? I didn't need the hood struts either, but did it anyway. Millions of vehicles don't have vent visors or flag decal on side windows, but I do. I like to play with my toys. But thanks for the input. .. ?
The items I added are functional and for a look I wanted. A gas cap serves no function. More of an inconvenience if anything but 'whatever floats your boat'. :wink:
daShadow
Vern
Western WA
2024 Bronco Sport
The function of the gas cap is to make me happy, and it does. It's hardly an inconvenience to flip it on and off. And yes, "my boat is floated". Sorry that my plastic cap bothers you so much. ... ?
Hitman11
E
Houston
Good to know, thanks! Def post when you install the rear as well.
Finally got a chance to install the rear sway bar. In theory it's a super easy install. In reality, getting the oem bar out and the steeda bar in is a real PITA; unless you disconnect the drive shaft. I decided to leave the drive shaft alone. Several hours later, after lots of hand nicks, some sledge hammering, metal on metal surface damage and lots of four letter words, I was able to get the steeda bar on. The geometry of the bar and the tight space is just a bad combo. Thank goodness the bar is under the car and not visible because it definitely no longer looks new. Alas, I got it installed and will update you once I take it for a test drive. Here are some before and after shots, whatever I could manage anyway.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240612_003555
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240612_003602
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240611_231005
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240611_162527
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240611_162418
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240611_162433
benbcholms
Ben
Youch. Sounds painful. Glad you got it in before having to take out the shaft. Here's hoping the drive is better with all the effort you put in!
They appear to be the same diameter. Is the Steeda supposed to be stiffer or softer?
Hitman11
E
Houston
The heat shield has very sharp edges
I noticed that as well. It's supposed to be stiffer but the biggest change is the ability to change the end link position on the steeda bar. I'm guessing it increases stiffness due to increased resistance of the bar thus reducing twisting on the bar itself and thus less movement in rear wheels relative to each other.
Colonel Angus
Dean
New York
For a minute there I thought this might be another part Ford left off to save money. :D
ATLAS BLUE BADLANDS
PNW
2024 BADLANDS
Tigger
Tigger
Illinois
Installed HRG molle panel. Easy install and seems pretty solid
Ford Bronco Sport What did you do TO your Bronco Sport today? moll
I hate to be a pain in the ass, but could you please take some more pictures of this? Most specifically, from the outside and from the hatch. I think this looks likes it fits my needs but I’m having a hard time visualizing from this pic.
