Jmuns
2022 Bronco Sport BL
tucg15
Tony
NJ
2023 Ford Bronco Sport Big Bend
2023 Big Bend here. So far I’ved added, side rails, window wind guards, aeroskin II bug deflector, roof rails, fishing rod rack, rear bump step and those little black bronco logos. Love adding extras to customize look!
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_1716
Chevo1468
Juan
South Texas
2022 Bronco Sport Outer Banks
Are the side marker bulbs LED?
According to the manual.
Replacing the Side Marker Bulbs
Side marker bulbs are LED and are not serviceable. See an authorized dealer if they fail.
If not LED, do the lenses pop off or does the bulb change have to be done from the back?
I don't recall if they were LED. The entire set up pops off and u replace it with the new full set up. It's just unplugging the old and plugging the new. Not sure if that answered your question. I can get u the photos of the old and new if you'd like.
Yes LED:
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_1930
Does the side light marker come off when pried front to back or back to front to loosen the clip?
It is from the owners manual but the owners manual isn’t always reality lol
They may be LED.
BS manual.
Maverick manual
CHANGING A FRONT SIDE MARKER LAMP BULB E349259
1. Use a suitable tool, for example a trim tool, to push the lamp forward.
2. Pull the lamp out. E349260
3. Remove the bulb holder from the lamp assembly by turning it counterclockwise and pulling it straight out.
4. Disconnect the bulb from the electrical connector.
5. To install, reverse the removal procedure.
It comes out the front, but you have to get behind them to compress the ”arrowhead” clips that hold them in. I found a pair of pliers like one of these was the best tool for the job.
Ford Bronco Sport What did you do TO your Bronco Sport today? 1709680931432
Look for “hose pliers”
