Hood insulator pad.
Mrmike
Syracuse, New York 13219
I put bottom screws on the license plates. Dealers deliver with only two top screws, leaving the plates half installed. WHY!$%$?
Bet they didn't forget the license plate frame with their name on it
I had the dealer remove the dealer sticker in the back before delivery. I also use a black stainless steel frame.
davidg4781
If I remember, the rear plates only has holes for the top two. The front has holes for the bottom but also has clips.
Horse n Buggy
Stoge
Florida, USA
Today I installed both the JCR front center console MOLLE panel and the JCR rear hatch MOLLE panel.
I used the installation guide videos on their website for both of these installs and they were relatively easy and straightforward and I had no unexpected hiccups in the process except for a minor issue with the Center Console panels.
Working doors open on a stool or on your knees while trying to awkwardly brace those damn metal panels and keep them somewhat symmetrical was not fun and not pleasant.
I installed every piece with the included hardware but long term (eventually) I think I'd like to change from the coarse thread screws on the front panels to a Rivnut connection.
I can confirm that the rear hatch panel is compatible with the OE cargo organizer shelf though you won't be able to open or close the shelf with the trunk closed through the lift glass.
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230618_232230399
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230618_232319240
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230618_232357362
SWUKU
GB
KY
Installed new, Black, 1-piece lug nuts.
Dp Accessories closed-end M12 x 1.5 thread / 19mm hex bulge acorn conical style.
About $40 for the set @ Amazon. Part # underlined in Red.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230617_192753
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230617_181903
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230617_181427
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230617_181409
Ford Bronco Sport What did you do TO your Bronco Sport today? Screenshot_20230619-204857_Amazon Shopping
Horse n Buggy
Stoge
Florida, USA
Edited post to embed manufacturer links for the products
I did an oil change and then took some pictures to create a post that shows people where to put the jack and the jack stands. Not really a complete guide, if you have no idea what you are doing. More of a general guide for those with some basic knowledge.
Look here if you are interested.
JohnSilver
Knoxville
Rhino rack pioneer platform installed. Wanted to get as low profile as possible with minimal overhang, took some modification to get it flush and level but I think it turned out good. Used the universal platform with some amazon stealth bars. The width was 46in compared to 49in and was about $300 cheaper
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230623_004420634.MP
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230623_004428138.MP
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230623_004435969.MP
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230623_004441679.MP
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230623_004654982.MP
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230623_005528714.PORTRAIT
