- First Name
- Robert
- Joined
- Mar 23, 2021
- Threads
- 1
- Messages
- 929
- Reaction score
- 1,083
- Location
- California
- Vehicle(s)
- Bronco Sport
I have my Badlands dealer serviced, they use Motorcraft synthetic blend oil and Motorcraft oil filters.
There are two primary reasons to change the oil. The first is loss of lubricity as oil ages. The other, and IMHO more important, is the amount of contaminants the oil holds in suspension. Using a full synthetic will extend the time you may use an oil before lubricity is decreased enough to affect how well it lubricates. A full synthetic cannot, however, hold more contaminants in suspension--that's mainly limited by the sump capacity.2) Using the engine life computer in the vehicles, they are calibrated to the synthetic blend, is there a way to recalibrate, or is it not worth checking into?
Just meet the spec. I had some leftover Mobil1 5-30 full synthetic around but it was petroleum graded for SN service and the book calls for SP. I picked up some newly crafted SP spec even though the oil is probably identical.
More important is probably the filter. You really don't want a filter to either fail or fill up. All modern filters have something for a bypass so you don't lose oil pressure. That means if the filter material fills with crud, you won't know it. It's designed to deliver oil no matter what. You can buy better filters with more material surfaces or a bigger filter. I haven't looked into it much, but a lot of filters have another size that is identical thread and seal but longer (i.e. more material) body. Something like that may exist for these engines.
By the way, I'm using 5-30 because the 2.0 calls for it. I think the 1.5 calls for 0-20. Don't get mixed up and don't just pick another viscosity unless you've done more engineering that the designer has.
My Walmart doesn't carry Motorcraft anymore.... Motorcraft synthetic blend and Motorctaft filter. I get the oil and filter at Walmart ...
It's more expensive, but every teardown of oil filters I have seen has the WIX oil filter at, or near, the top. Still pretty cheap from RockAuto if you are willing to buy a half dozen or so.My Walmart doesn't carry Motorcraft anymore.
Looked in the box of a Mobil 1 filter before I bought it, and it had the cheapo blue filter. Gave it to an employee stocking shelves in the next aisle. They picked up a Mobil 1 box on their cart, "and this one was empty."
I bought a sell pack of 12 Motorcraft filters at Rockauto.com last year. $44.64. $3.72 each. Tax and shipping brought it to $54.27. $4.52 each.
Still just $3.74 each as the 12-pack.
2021 FORD BRONCO SPORT 2.0L L4 Turbocharged Oil Filter | RockAuto
The NAPA Gold are said to be manufactured by Wix.It's more expensive, but every teardown of oil filters I have seen has the WIX oil filter at, or near, the top. Still pretty cheap from RockAuto if you are willing to buy a half dozen or so.
For oil, I have decided to use the Castrol Edge Extended because of the lower NOACK volatility rating I found somewhere for Castrol. The lowest that I saw was for Amsoil but that is harder to get and more expensive. The NOACK is important in a Direct Injection engine to help keep intake valves clean.
Perfect combination in my opinion. That's exactly how I do it myself. Only difference is that I still do it myself. I'm 79 though, so I might have to start going to the dealer soon.I use full synthetic and have it changed every 5000 along with tire rotation at my Ford dealership.
