BSoftRoader
Gavin
Austin tx
22 Bronco sport
Hey all , just joined up and thought I would give you a quick rundown of the BS as it stands today.
I’m debating taking the rear spacer lift off to level the BS I was able to keep the front factory tow-hooks and paint them.
the tires do not rub but there are close at full lock.
2022 badlands
1.25” HRG Lift
245/70r17 BFG KO2
Fifteen52 wheels
Rough country nudge bar
Rhino rack pioneer platform
Magnaflow dual exhaust
Ford Bronco Sport 2022 Badlands lifted on 1.25” HRG Lift and BFG Ko2 56A25BB7-04C3-4CD8-B78A-D6D78DAEFCED
2022 badlands
1.25” HRG Lift
245/70r17 BFG KO2
Fifteen52 wheels
Looks good. I thought the RC nudge bar wasn’t compatible with the Badlands. Also, is the offset of your Fifteen52 wheels the same as stock?
Edit: saw your other posting showing how you notched out the support bracket on the RC nudge bar.
BSoftRoader
BSoftRoader
Gavin
Austin tx
22 Bronco sport
The fifteen52’s are 38mm the stock wheels were 37.5 so close enough!
Yes as they ship today, the nudge bar brackets are built in a way you would have to remove the tow hooks. I just trimmed/notched the RC brackets to allow the tow hooks to stay.
being that the nudge bar is essentially cosmetic I saw no real risk in notching the bracket.
Ford Bronco Sport 2022 Badlands lifted on 1.25” HRG Lift and BFG Ko2 77D77D6D-B213-475E-B4C1-393C16ED4B55
Ford Bronco Sport 2022 Badlands lifted on 1.25” HRG Lift and BFG Ko2 8E76BB86-80EB-4EAC-954D-6B20994300CA
Folkman
AZ
bit.ly
I like the fix for the recovery points!!! I guess when my CFO (wife) decides I can spend more money I may have another project.
Getting my BS picked up (BL) today with the HRG lift and new tires (245/65r17). Didn't go full 70s as the pro-shop has tried before and got rubbing on full flex. The trails here WILL fully flex the suspension for sure. But MAN those 70s look hot.
Got my LocknLoad on the way with awning too.... So I spent enough $$ for now in her mind (and mine too). Priorities :cool:
JordanVaca
Jordan
Central Texas
Ford Bronco Sport Outerbanks
2022 badlands
1.25” HRG Lift
245/70r17 BFG KO2
Fifteen52 wheels
looks extremely good, well done.
FirsandFire
Ken
HV, NY
Looks damn good. I love the wheels with the paint color, nice contrast.
BravoAlpha
Oklahoma
love it. Best looking rig I’ve seen yet.
Reactions: Jrl
Ricardo
El Paso, Texas
2022 Ford Bronco Sport, 2011 Ford F150 XLT
Looking good! Considered those wheels as an option for ours, would’ve been glad I went with those as well, might go with those down the line.
Fifteen52 wheels
BTW, not only does that validate the wheel color I’m planning on but the specs of that wheel also match the ones I found, so that validates that they will fit (width and offset). Thanks again!
BSoftRoader
BSoftRoader
Gavin
Austin tx
22 Bronco sport
Appreciate it! It looks even better off road!
Ford Bronco Sport 2022 Badlands lifted on 1.25” HRG Lift and BFG Ko2 4CF9D8AB-B8F8-41D6-9C88-EAA3346D9E6A
and starting to not look like a toy compIred to its big brother. With the roof platform I’m at the same roof height as a Sasquatch ?
Ford Bronco Sport 2022 Badlands lifted on 1.25” HRG Lift and BFG Ko2 B966643B-BAD1-4D5E-BBF6-1FBBABDFD7A2
notabumblebee
2022 BroncoSport
Any rubbing while off road or full articulation? Looks great.
Jmuns
2022 Bronco Sport BL
Did you prepare the tow hooks before you painted them? What kind of paint did you use?
NEFKANO
NEFTALI
El Paso, Texas
neftalicano.com
Wow... exactly what I'm looking to do to my BL... in same color as yours. My biggest concern is whether or not adding a lift "will" violate my Ford warranty... I purchased an extended Ford-Premium (not 3rd party extended warranty) and worried adding any lift would violate that. Do you or any others here know...
If you were to have a suspension component or CV joint/axle issue, it is possible (maybe even likely) that the warranty claim would be denied. Could depend on the dealer you took it to for that claim and if they reported that you had it lifted. Any/all other items would be covered by the warranty. A modification does not void the entire warranty but they can claim that something you changed caused the failure.
