Your Bronco Sport has been put into Deep Sleep mode
rocks
SC
Ford is aware of the battery issue. I wonder if maybe the '23 and more so the '24 models have or will have upgraded batteries.
Robink
Robin
Utah
Ford Bronco sport
Another factor, how long are your usual drives? I’ve killed batteries on several cars with short commutes and errands. I put a hood solar panel on for that, and to offset all the vampire loads from computers, headlight cooling fans, etc. while camping. More things to drain the battery while parked with most new cars. Anecdotally, it feels like newer cars have a bit undersized batteries and alternators that are less amenable to frequent short drives
As for the stop/start, I think it has multiple conditions to activate. Something beyond voltage and engine temp. It often works in less five minutes for me if I’m parked in the sun on a hot day. Cold day with lots of errands, parking out of the sun, maybe half an hour. It’s not consistent enough for it only to be about temp and voltage though.
Oh, and do you have any accessories you plug in while driving? The start/stop turns off if you exceed a certain load on the 12v or 110v outlets
I just went camping for the first time in my 21 BB for a week and every time I opened a door or something the fans would run for 10 minutes. I've had this car for a couple of months. I was worried that the battery would die. What is a hood solar panel?
wireman
Murrieta
I just returned from a 4,000 mile road trip and the start/stop feature is an enigma.
I've always had issues with it. It's a lead acid battery. Service checked it and of course nothing's wrong. Just drive it more often. I guess there are 13
parameters needed for it to operate.
On this trip I've driven as much as 500 miles a day and sometimes it wouldn't work even with the battery fully charged. Then other times it would. No consistency on how it operated.
Why Ford put a lead acid battery in this vehicle is questionable. They won't replace it and I sure as hell aren't paying for it until there comes a point it's needed. It will be an AGM.
rocks
SC
I hate that stop/start and turn it off when I start the BS up. Something I've done on every vehicle I had with that stupid thing.
Colonel Angus
Dean
New York
I have a 6/23 build date in my BB. I will check later and look to see if it is an AGM battery. Fingers crossed. ?
rocks
SC
I seriously doubt it will be an AGM but at least maybe an upgraded acid battery.
Maxwellian
Maxwell
Los Angeles
‘21 Bronco Sport
Yeah, I think they run just to clear condensation, in case you start driving. Hatch glass doesn’t seem to turn them on, not sure about whole hatch or back doors
My solar setup is just a cheap 50w semi-flexible panel on a hood vinyl.
https://www.broncosportforum.com/forum/threads/for-those-with-the-hood-liner-and-struts.6976/post-123352
Colonel Angus
Dean
New York
I think you're right. I don't see anything that says AGM. Cheapo Lead Acid. As long as I get till the warranty is up with it I guess I can't complain. Just so I know to set my battery tender correctly.
Ford Bronco Sport Your Bronco Sport has been put into Deep Sleep mode IMG_2124
rocks
SC
I posted the same battery numbers in the Mechanical and Maintenance and Servicing forum.
Robink
Robin
Utah
Ford Bronco sport
biglarrr
Larry
NW Indiana
Hi there, I'd be happy to look into your Bronco concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
if I've read other responder's comments correctly, you basically contact the dealership's Service department, and tell them to have me bring my car in.
i also get the impression, as you would also if you read these forums that Ford considers this a minor annoyance, and will replace the battery if you nag, nag, nag, and contact Ford customer service, which I have already done. And I'm just guessing here, but I got the strong impression, that Ford is giving service departments grief about replacing the battery now - probably because there have been so many replaced under warranty. It's pretty obvious to me that it's not the battery. It's something in the programming - probably hardcoded - since if it was as simple as a software update, it probably would have been done by now.
So - if You're going to actually research this, instead of just passing it on to the service manager, who probably cringes now when he sees me come in the door, I'll give you the information you asked for, but I'm not taking it in for service again, since five visits have only resulted in a new battery that did not resolve the issue.
It's a shame that one responder actually said they put battery tenders on every one of the Fords in their fleet because of this issue.
Maxwellian
Maxwell
Los Angeles
‘21 Bronco Sport
Too bad they aren't available! When I open the hatch glass or the hatch the fans go on. Such a crazy design.
Oh, maybe I just wasn’t hearing them from back there. I know it doesn’t turn on the bronco rock animation on the screen.
Not finding as good of a deal now on panels, mine was $80.
Lensunsolar 50W for $129 is the best deal I can find from Jeff https://a.co/d/1idrjCh
Same company has a 65w made to fit the Bronco Sport, but it’s $289.
https://www.lensunsolar.com/index.php?route=product/product&product_id=544&search=Bronco+
... It's pretty obvious to me that it's not the battery. It's something in the programming - probably hardcoded - since if it was as simple as a software update, it probably would have been done by now.
@biglarrr You guessed pretty good, it can be a software programming error (this was stated by several Ford techs and a Ford dealership parts dept person) but is a software timing error. So yes a software bug is one of several reasons the Deep Sleep mode message pops up (there can of course be a real issue with the battery and or electrical system). As it’s been stated, “deep sleep glitch: all it takes is for 1 module to not respond fast enough causing the vehicle to think the battery is not working correctly”. In my opinion this is not likely going to be fixed by Ford because if you google the issue it has been ongoing for many years across many different Ford vehicles not just the Bronco Sport.
GulfCoastBronco
Topher
Corpus
Sorry if I am repeating any other info already mentioned.
But I do believe across all Ford models once the battery drops below a certain voltage the stop/start fails to work properly. There is also a thread on here I believe about people feeling manufactures aren’t using the same quality batteries as they once were and some are experiencing needing batteries replaced within a year. The other thing I have found strange is my father recently has his battery changed on 2020 F-150 and the dealership claimed they needed to reset the electronics in order to function properly with start/stop and other new age features. I found that ti be really strange but he said his neighbor has the same issue but changed his own battery and ended up having ti go back to dealer to have them reset whatever internal gizmo needs resetting. Not sure if anyone has talked about that, or if it’s even needed on the Bronco sport. I hope the issue gets fixed good luck to you.
… The other thing I have found strange is …the dealership claimed they needed to reset the electronics in order to function properly with start/stop and other new age features
Yes .. it is needed …
Ford BMS Battery Monitoring System: How it Works and How to Properly Charge Your Battery!
