- First Name
- Larry
- Joined
- Nov 22, 2022
- Threads
- 4
- Messages
- 79
- Reaction score
- 45
- Location
- NW Indiana
- Vehicle(s)
- 2022 Bronco Sport
Some of you may have seen my battery issue post from a few months ago. I actually quit this forum because of the non-supportive remarks.
.I've either got a one of a kind electrical issue, or a known issue that people just don't know or care about.
i don't put a lot of miles on my BSOB. after 18 months I've barely got 6000 miles on it.
I noticed this issue about four months after I purchased it.
The "Start/Stop feature quit working first. I went to the manual, and YouTube, and finally this forum looking for a solution.
As it turns out, when the battery drops below some mysterious level, all kinds of things quit working, the most noticeable (if you use it) is the start/Stop feature.
I went to Ford Service, and the first answer I got was "Oh it won't work when the temp is less than 40 degrees. It happened to be about 35 degrees that day. This had been going on for well over a month in warmer weather, so I was not convinced. I had to take it in for a different issue, and asked them to check the battery, since I had started monitoring it, and it was dropping below 12 volts just sitting overnight. This time they said the battery was discharged and kept it for two days and the only thing on the service report was "Charged battery". It worked (for three days) and then it was back to features not working and I showing drops overnight. I brought it back in and asked them to check the alternator, or whatever charges these 21st century computerized nightmares. Their response was "The alternator's alright, it would show up on the report we run if it wasn't. They also claimed they tested the battery and it was good. The issue continued and I brought it in again for a window part that had been backordered and told them the voltage was still dropping. By chance - a specialist tech that travels to multple dealerships to deal with issues was there working on a different vehicle. He told the tech working on my car to run a level 2 battery diagnostic. It failed, and they installed a new battery. I thought the issue was finally resolved. Everything worked fine for about five weeks. I even quit running voltage checks because they seemed to be holding above 12 volts.
Then one day the Start/Stop failed and the issue was back. I charged the battery with my agm charger, and everything started working for a few days.
Then I didn't drive it for a couple of days, and I got a message that my BSOB had been put into Deep Sleep mode, and if I couldn't start it, I should call the Service department. It also went on to say that I could resolve the issue myself by going for a drive "REALLY" it actually says that.
So Your battery is going to drain in three days if you don't drive it, and you will have to go for an hour drive to charge it.
I'm not exaggerating that hour drive. I had to drive for nearly an hour before I stopped at a red light and the Start/stop worked. This is crazy stuff.
Once again - I've written a book, but I hope you understand that I have tried to figure this out, and tried to trust Ford to help out, and have basically been told - no LITERALLY been told by the manager of the Service department - that if i'm not having any other issues, I should just drive it.
Please - somebody - tell me there is a solution for this.
