Sync Navigation Map Update NA 2 23 Now Available
I downloaded the files and started the update, but I got an error SIGN_ERR02 (hashtag mismatch) telling me to download the files and try again. But the complementary download option was gone. I had to purchase the USB from Ford. Smooth move Ford, smooth move, keep sticking it to your customers.
If it happens again, or now even, email the maps support team. They can find your complimentary order and reissue you a download link. They've done it for me before. Might be worth reaching out to them and asking for a refund on the USB.
Caliope
Lisa
Illinois
You may want to check on Fords Sync website as many other ‘22 owners report their ‘22 has between 3 to 5 free Nav Maps updates (by downloading to your computer).
I am not sure if the number of free Maps updates for the ‘22s is determined by which model and package was purchased (I have the 2022 Bronco Sport Badlands with Ford Co-Pilot360 Assist+ (Premium Package) and have received 3 Maps updates via download method so far).
I also have the Premium Package. I remember receiving an email from Ford last year saying that if I wanted the nav updates I needed to subscribe to get them.
Yep I got the same email as you but so far have received 3 free updates all by downloading
Did you click on the link in the opening post to see if you are eligible for a no charge download?
I’ve had the same Gracenote Version: 1.1.1.2323 (NA-0020) since Navigation Maps Version: NA 2 21.
does it show during your installation that Gracenote was update or how do you know that Gracenote was updated?
Ford Bronco Sport Sync Navigation Map Update NA 2 23 Now Available IMG_4155
The Gracenote file is 4U5T-14G423-CC
I did not find the file in the Navigation Map update NA 2 23
Do you still have your download of Sync 3.4 Build 23188? The Gracenote file may be in there.
Bronclahoma
Oklahoma
Too expensive and complicated for a very mediocre nav program. I already have Google Maps, WAZE, Apple Maps and OnX. Don't see I need he Ford app.
wireman
Murrieta
2021 Badlands. Had a couple of free updates before. Now I have to pay $109 for the download.
Ford can stick it. I'm not about to pay that amount to update a mediocre Nav system.
I'd probably never notice any changes and there's always Google maps, etc. if needed.
DWG
If navigation is important to you be thankful that we do not have sync 4. Ford gives you navigation but maps will not work unless you subscribe for $80 per year.
At least with sync 3 the navigation works even if the maps are not updated. For me I have no need to update the maps every year as where I usually travel nothing much changes. I will at least skip at least a couple of years before updating.
rocks
SC
What is the benefit, if any of updated Gracenote? What is Gracenote?
RushMan
Russ
NW NJ
'24 Shadow Black Badlands
The person I talked with, said try the download after 24 hours, and call back either way, if it works or if it doesn't.
Here it is, more than 24 hours later. The complimentary download still doesn't work and produces the same error message:
"Your order cannot be completed at this time. Please contact customer service at (800) 392-3673 to report this error.(016) "
I believe your only way forward is discussed in Post #38. Happened to me as well with a brand new VIN.
RushMan
Russ
NW NJ
I believe your are right. For the heck of it, I tried to order the Thumb drive. Same error!
It makes no sense since the Scan for updates on the web sites show that I am eligible for the "Complimentary" Nav map update.
@thomasm23 I did not find Gracenote file 4U5T-14G423-CC saved on my computer…
There is no *14G423* named file for any of these which I had saved on my computer:
Sync 3.4 22251
Sync 3.4 23188
Nav Maps 2.22
Nav Maps 2.23
Google states the 4U5T-14G423-CC came with Sync 3.4 21020 but that was for F-150. I no longer have SYNC 3.4 22200 so I cannot check for the Gracenote file in 22200. My ‘22 came with SYNC 3.4 21194 installed by the factory.
Cyanlabs states there are size issues with Gracenote (too large) and Sync 3.4 did not get the 4U5T-14G423-CC because it is too large. However there is much conflicting info on Cyanlabs so don’t take that as fact.
My Display shows
Gracenote Version: 1.1.1.2323 (NA-0020).
And Google states Gracenote has a later version which we do not have in Sync 3.4.
The filename decoder ring for Sync and Navigation indicates:
4U5T: 2018
14G423: Gracenote files
CC:
Region: NA_NA
Files: xxxx-14G423-Cx
Languages: ENU, FRC, SPM
https://community.cyanlabs.net/t/sync-in-vehicle-software-update-ivsu-file-naming-convention/5579
Well maybe is counterintuitive but does make sense because Ford’s vendor ALOM Technologies may not have your VIN known to them which is what happened with my new ‘22 back in 2022.
The only way I know is for a Ford customer service specialist to work directly with ALOM Technologies to have ALOM create the USB Thumb drive for your VIN then mail that drive to you at no cost for your troubles. Well that is my recommendation of a perfect solution. Good luck!
