Looks awesome man.Looks great!
I think it looks good with all four. And why aren't you happy with the headlights wire? Is that also the DRL wire? Why would you want to go with the foglights wire?Drilling into the honeycomb grille was a little sketchy but pulled it off. I went with four raptor lights spliced into the head lifts wire (thick brown and blue wire driver side.)
Wish I went with the fog lights wire.
I’m having slight regrets of just doing the 3 lights instead of the 4… looks real nice.Drilling into the honeycomb grille was a little sketchy but pulled it off. I went with four raptor lights spliced into the head lifts wire (thick brown and blue wire driver side.)
It was a tight squeeze installing the raptor lights closest to the headlights. I used a tiny screwdriver for glasses to bolt them on. Dam near impossible to fit your hand back behind the grille there.I’m having slight regrets of just doing the 3 lights instead of the 4… looks real nice.
Are you going to put some wire mesh overlay to finish the look?
Yes, the DRL wire.I think it looks good with all four. And why aren't you happy with the headlights wire? Is that also the DRL wire? Why would you want to go with the foglights wire?
Yeah, even for mine it was a tight squeeze, and I really didn’t want to take the whole front off again after installing the nudge bar.It was a tight squeeze installing the raptor lights closest to the headlights. I used a tiny screwdriver for glasses to bolt them on. Dam near impossible to fit your hand back behind the grille there.
I may use the mesh so it's looks sealed. Still considering it
My only note for the mesh is that the center slot is not as wide as the outside slots, so you need to cut 2 different mesh widths.
and the only way I got my mesh inserts to fit was with some rubber edge stripping that I glued to the mesh after bending to the appropriate shape.
im working on a 3D print PLA mesh insert To replace it, but I’m far from that being finished. Overall though, it really makes the front pop with the accent lights underneath.
nice build!
You mean, late May! It was 88 yesterday and the high was this morning at 42 but now 33. In 24 hours it is 55 degrees cooler. At one point last night at my house it dropped 30 degrees in about an hour.W
eather Late April?
#coloradonative
Must of been 4/20 in my brain stillYou mean, late May! It was 88 yesterday and the high was this morning at 42 but now 33. In 24 hours it is 55 degrees cooler. At one point last night at my house it dropped 30 degrees in about an hour.
How did you get to the parking light? Looks pretty tightI spliced into the driver’s side front parking light and it worked perfectly.
I removed the wheel well liner and then removed the black fabric tape that has the wires doubled back. It was a little tight, but there was just enough room. Use the three way wire taps I linked in an earlier post.How did you get to the parking light? Looks pretty tight
Thread starter | Similar threads | Forum | Replies | Date |
Raptor Lights installed on Big Bend | Lighting | 21 | ||
Easy to install Raptor lights? | Lighting | 1 | ||
Raptor style lights | Lighting | 2 | ||
Raptor style grill marker lights cheap and easy | Lighting | 7 | ||
Raptor grille light ideas? | Lighting | 15 |
