Raptor grill accent lights
compass crusher
Nathan
linktr.ee
Drilling into the honeycomb? grille was a little sketchy but pulled it off. I went with four raptor lights spliced into the head lights wire (thick brown and blue wire driver side.)
Wish I went with the fog lights wire.
Ford Bronco Sport Raptor grill accent lights 20220517_095556
madfella
El Paso
Drilling into the honeycomb? grille was a little sketchy but pulled it off. I went with four raptor lights spliced into the head lifts wire (thick brown and blue wire driver side.)
I think it looks good with all four. And why aren't you happy with the headlights wire? Is that also the DRL wire? Why would you want to go with the foglights wire?
Pmk1710
Peter
I’m having slight regrets of just doing the 3 lights instead of the 4… looks real nice.
Are you going to put some wire mesh overlay to finish the look?
compass crusher
Nathan
linktr.ee
It was a tight squeeze installing the raptor lights closest to the headlights. I used a tiny screwdriver for glasses to bolt them on. Dam near impossible to fit your hand back behind the grille there.
I may use the mesh so it's looks sealed. Still considering it :)
compass crusher
Nathan
linktr.ee
Yes, the DRL wire.
I thought the raptor lights would turn on with the day time dimmers and stay on during the day. When spliced into the DRL wire the raptor lights only turn on when you turn on the headlights.
I was thinking about connecting the lights to the fog lights wire because there more aesthetically pleasing with both on. The raptor lights cut through the fog better than I thought.
Pmk1710
Peter
Yeah, even for mine it was a tight squeeze, and I really didn’t want to take the whole front off again after installing the nudge bar.
My only note for the mesh is that the center slot is not as wide as the outside slots, so you need to cut 2 different mesh widths.
and the only way I got my mesh inserts to fit was with some rubber edge stripping that I glued to the mesh after bending to the appropriate shape.
im working on a 3D print PLA mesh insert To replace it, but I’m far from that being finished. Overall though, it really makes the front pop with the accent lights underneath.
nice build!
compass crusher
Nathan
linktr.ee
nice build!
Noted :), I'll most likely install the mesh sometime next week. Looks more slick and flush with the whole setup.
When you finish send pics. Your BS is looking sweet!
W
Ford Bronco Sport Raptor grill accent lights 20220520_132001
eather Late April???
#coloradonative
You mean, late May! It was 88 yesterday and the high was this morning at 42 but now 33. In 24 hours it is 55 degrees cooler. At one point last night at my house it dropped 30 degrees in about an hour.
BlackPearl
Silvia
Aberdeen, MD
Has anyone with a badlands grill installed raptor/accent lights yet?
OB_Bronco21
Ethan
I spliced into the driver’s side front parking light and it worked perfectly.
Ford Bronco Sport Raptor grill accent lights ED3EE127-ED87-43B3-9BC6-056E68DE0AE6
How did you get to the parking light? Looks pretty tight
madfella
El Paso
I removed the wheel well liner and then removed the black fabric tape that has the wires doubled back. It was a little tight, but there was just enough room. Use the three way wire taps I linked in an earlier post.
