Looks great!
A winch would fit perfectly in between your nudge bar lights?.
Looks great!
	Yeah… I’ve put down a few hints to the wife and kids for Fathers Day presentsLooks great!
A winch would fit perfectly in between your nudge bar lights?.![]()
Did you splice into the parking lights? Or run them separate into a lighting control for your other lights?
they are low amperage, so I don’t think there would be an issue if you did splice into the parking lights.Did you splice into the parking lights? Or run them separate into a lighting control for your other lights?
I spliced into the driver’s side front parking light and it worked perfectly.Did you splice into the parking lights? Or run them separate into a lighting control for your other lights?
	Exactly which lights did you use? Have a link to them?I spliced into the driver’s side front parking light and it worked perfectly.
Nice! I didn’t want to mess too much with splicing after reading a bunch of wiring horror stories with the BS. Glad it worked out for you!I spliced into the driver’s side front parking light and it worked perfectly.
I would never use that winch; that bull bar isn't connected to the frame as the tow hooks do. Looks great but might do some damage if used.Looks great!
Is that the marker light at the bottom of the bumperI spliced into the driver’s side front parking light and it worked perfectly.
Here you go:Exactly which lights did you use? Have a link to them?
Yessir! There is very little wire to work with but it wasn’t too hard. And just to save everyone time, hot is the blue/lavender wire.Is that the marker light at the bottom of the bumper
It was actually pretty easy. Just make sure your connection is water tight. I used these:Nice! I didn’t want to mess too much with splicing after reading a bunch of wiring horror stories with the BS. Glad it worked out for you!
	Looks great!Just finished mine......so much easier than I anticipated!
