Issue with CarPlay
Debbiew
Debbie
Poway
Does anyone else's Bronco Sport 2025 have issues connecting to CarPlay? Mine will even say that CarPlay is not enable while it IS playing my book but not all the way loaded into CarPlay mode. Other times it simply does not connect. CarPlay worked fine on my 2021 but I have struggled with this one since I got it. This happens wirelessly and plugged into a cable. I have an iPhone if that matters and it is updated.
No issues with my '25. Three different iPhones from a 13 to a 17 all connected just fine. Does your iPhone even show up as a connected device? If so, try disconnecting and reconnecting. If not, double-check your settings in both the BS and iPhone, make sure they see each other in Bluetooth.
thomasm23
Los Angeles Metro
We need to know the year of your vehicle.
We also need to know the version of iOS installed on your device.
Are you using CarPlay with a cable or wirelessly?
dwrufus53
Don
Phoenix metro
She included two thirds of the answers in her original post.
FWIW, I have only had one instance of any weirdness with CarPlay in my 2025 Bronco Sport. In that instance, it failed to connect. I fixed it by restarting both my iPhone (tap vol up, tap vol down, hold power until you see the apple logo) and the infotainment system (hold fast forward/call hang up steering wheel button and the radio power button until you see the Bronco logo).
Once both were restarted, it connected and has been rock solid since.
dwrufus53
Don
Phoenix metro
Mine every now and then will disconnect then all of a sudden re-connect.
What phone and what version of iOS? There's a known bug in iOS 26 that has caused this. It seems to be fixed in 26.1 beta 4.
TheDude
Tampa, FL
17 pro max. On the latest 26.0.1 and still does it.
Debbiew
Debbie
Poway
I have restarted my phone many times, but will try your infotainment system re-start. So weird after having zero issues with my 2021.
Thanks
dwrufus53
Don
Phoenix metro
The current beta release does fix that, according to the reports. I have the beta, but have not experienced the issue.
Hopefully 26.1 will be out in a week or so.
elvisimprsntr
Elvis
'25 BS BB
no issues here on the latest 26.1b4
Brent@ANParts
Diamond Sponsor
Brent
www.autonationparts.com
Ford Bronco
I've personally been having a lot of issues with CarPlay since iOS 26, but I haven't updated to the latest version yet. Hopefully that solves it, as it's affecting multiple cars I drive.
Deleted member 12075
My only issue with my 21 BB is it will not "voice command directions" while in "maps", but will when I'm in "google maps" which means I need to type in the directions instead of just initiating them from my calendar. I suppose I could just use the google calendar instead though.
I just bought a used 2025 BL. My Sync 4 version is 24242.
Revision 1356.
I have auto update turned on and when I check, it shows no updates available.
Is this the latest version ?
dwrufus53
Don
Phoenix metro
Ford Bronco Sport Issue with CarPlay IMG_4195
DWG
New Jersey
May not be on point to this thread but I have been driving a 25 Big Ben Loaner with Sync 4. It does not have navigation but I have noticed that if I have Apple Car Play enabled the iPhone is not connected through bluetooth. If I disconnect Car Play by turning it off in the Bluetooth settings for the BS than Bluetooth connects. I have an iPhone 15 with the IOS 18.7.1
