Is there a way to disable the Wireless charger in the Bronco Sport?
Closest I've found is talk of pulling a fuse, but unclear if its a shared fuse or just for the feature. Perhaps someone can look or even test - I've seen some smart USB accessory fuses from the internet don't know more concretely. No bronco sport to tear apart (yet).
Why would be interested in disabling wireless charger:
- Phone case holds credit cards in the back. Not enough to disable charging, but enough to generate extra heat (enough to apparently melt some weaker plastics)
- Prefer wired charging, wired carplay
- Tried out wireless charging in general and this ain't the generation I can get behind
- Devices mostly weren't charged - on phone that was easier to see and correct but on accessories (e.g. airpods case) much harder to discern. End result: Annoyed devices not well charged up as desired after hours on the "charge"
- Had good success with magnetic USB-C dongles 1yr+ (despite them being technically out of spec/potential shorting out risk frying the hardware).
- Much worse luck with USBA/B (sloppy dongles/connection more than anything).
