Brakes making loud noise when backing up.
Jumbo1953
My 2021 BSBL with 37500 miles has made this noise for a couple years. As soon as I go forward and press the brakes once, it doesn’t do it. My Bronco has been nearly perfect and this annoying little sound won’t change my love for my Bronco Sport.
Xzavior1818
Anthony
Canton
Is the noise still present after a pad change? Was thinking about going with the powerstop z36s carbon ceramic pads. Rears are at 5mm and fronts are at 8mm right now
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
Unless you are going to the track there's no reason for carbon ceramic. Ceramic are just fine. But when I was looking the z17 and z36 were only a few dollars difference. I went with the z17
Xzavior1818
Anthony
Canton
Well I tow with my trailer alot. Sometimes close to the max tow rating of the sport. I have the z26s on my mustang and like the feel and also keeps the wheels clean. The carbon in the pad is supposed to increase the bite that you lose with just ceramic. I don't mind the extra few dollars. I save plenty just doing the labor myself.
Xzavior1818
Anthony
Canton
But also curious if a pad swap gets rid of this noise. Guess il update when I do them in 10k miles.
Deleted member 12075
Had TSB 24-2348 completed 12/5/2024 (covered under the 36 month 36k mile warranty):
SOP INSTALL BRAKE - IN REVERSE VEHICLE MOANS, REFER TO TSB 24-2348
BRO1 BRAKE CONCERN
2 DG9Z*2C150*B BOLT
1 SZ62*2200*A PAD - BRAKE (possibly is Brake Pad Clips Kit)
2020-2024 Escape, 2021-2024 Bronco Sport: Replace The Caliper Bushings, Guide Pins And Brake Pads On Both (2) Rear Brake Calipers
Following The Service Procedure Includes Time To Clean Bushing Housing And Add Grease (Can Be Claimed With Operation C, D, E, Or F) (Do Not Use With Any Other Labor Operations Outside Of This Article)
2021-2024 Bronco Sport: Additional Time To Machine Both Rear Disc Brake Rotors On Vehicle (Can Be Claimed with Operation A Or B)
242348E0.7 Hrs
242348B1.4 Hrs.
Also see:
https://static.nhtsa.gov/odi/tsbs/2024/MC-11009564-0001.pdf
Thanks for the info. My rig is quite a bit out of warrantee, but when the time comes I'll be ordering the bushing and spring kits suggested in the bulletin to go with the ceramic pads/drilled-slotted rotors I plan to replace the stock items with.
I've used Powerstop's pad and rotor kits on my last 3 vehicles. Outstanding products, never been disappointed in their performance. I NEVER skimp on brakes or suspension components. If your rig doesn't run, it's inconvenient for sure but if you can't control it, you're going to hurt yourself or others. For $298 (+shipping at "Crock-Auto"), I'd sleep better knowing I have superior braking.
