Add Auto-wipers? "WORKED!"
Interesting. Because your writing on the sensor is also at an angle, whereas mine is straight across.
Ford Bronco Sport Add Auto-wipers?  "WORKED!" IMG_3971
I see what you mean about the connector though. I can just pull that clip and rotate it to the other two pins that are there. 😊
Stircrazy
BC, Canada
they are different part numbers also yours is a Lu5t the black one is a Lt7T (thats what it looks like for my eyes.)
It’s the right part. I went off his private message and ordered it. I just needed to remove the clamp and rotate it like 30°. 😊
Ford Bronco Sport Add Auto-wipers?  "WORKED!" IMG_4008
Ford Bronco Sport Add Auto-wipers?  "WORKED!" IMG_4009
The correct part number is LU5Z-17D547-A.
The clips are loose!
Take it out and put it back in crooked. :muscle: :muscle: :muscle: :muscle:
I decided to keep this as OEM as possible. I ordered the proper electrical connector (which cost more than the sensor) as well as the wiper stalk.
pantera155
pantera155
Pantera
Argentina
Bronco BADLANDS 2025
The only thing that's changed on the wiper stalk is the small white symbol. :crackup:
You could have saved yourself a few dollars by drawing it with this: :crackup::crackup:
Ford Bronco Sport Add Auto-wipers?  "WORKED!" D_NQ_NP_614165-MLA100085278517_122025-O
pantera155
pantera155
Pantera
Argentina
If you still can't do it, just pay for my plane ticket to your house and I'll gladly install it for you!
:crackup: :crackup: :crackup:
Ford Bronco Sport Add Auto-wipers?  "WORKED!" photo_2026-03-04_01-05-25
Ford Bronco Sport Add Auto-wipers?  "WORKED!" photo_2026-03-04_01-05-25 (2)
I’m finally getting around to finishing this up… my overhead connector only has two spaces in between the blue and white stripe wire and the green and brown wire. According to your photo, the green and brown one was added for supplying 12v.
I do have, on the other row, and blank opening, with a corresponding pin on the male side.
Ford Bronco Sport Add Auto-wipers?  "WORKED!" IMG_5283
dwrufus53
Don
Phoenix metro
In my previous vehicle (Mazda 6) it had rain sensing wipers and I eventually turned it off as they had a mind of their own. I prefer the intermittent settings the regular wipers offer
Likewise. My wife's Ford Edge had them, too. She swore by them. I swore at them. :D
pantera155
pantera155
Pantera
Argentina
I think the correct photo is the one of the other connector, :crackup: . The one on the other side.
You need to put the 3 new wires into that connector and connect them to the sensor.
We understand by "another connector" that one is the male and the other the female.
