I see what you mean about the connector though. I can just pull that clip and rotate it to the other two pins that are there.Interesting. Because your writing on the sensor is also at an angle, whereas mine is straight across.
they are different part numbers also yours is a Lu5t the black one is a Lt7T (thats what it looks like for my eyes.)Interesting. Because your writing on the sensor is also at an angle, whereas mine is straight across.
It’s the right part. I went off his private message and ordered it. I just needed to remove the clamp and rotate it like 30°.they are different part numbers also yours is a Lu5t the black one is a Lt7T (thats what it looks like for my eyes.)
I decided to keep this as OEM as possible. I ordered the proper electrical connector (which cost more than the sensor) as well as the wiper stalk.The correct part number is LU5Z-17D547-A.
The clips are loose!
Take it out and put it back in crooked.![]()
