110v outlet
CrashBend
I have a 2021 OB. There is a 110v outlet at the rear of the center console. Today I plugged in a sawzall so I could cut some wood down at the river. I guess I should have checked it out at home before I wasted my time. The sawzall would not run at all on the meager amount of power being produced. And..yes I did have the engine running and yes the indicator light did show that the outlet was working. So. When Ford says it is 110v 150Watt they are stretching that a lot.
ScareCrow
Burl
Indiana
BS/Badlands
A sawzall needs a least 1,650 watts........
Maxwellian
Maxwell
Los Angeles
ā€˜21 Bronco Sport
Yeah, power tools are generally rated in amps only.
Reciprocating saws range from 8 to 15 amps at full power, so ~880 to 1650 watts at 110v.
Also, all but the biggest and fanciest inverters donā€™t deal well with spikes in current, and put out an AC wave form that some motors donā€™t like.
fourthgear
florida
It's meant to charge a Phone or Lap top or other such devices . Your post makes me want a battery operated Saws all now more than ever .
Desert Bronco.
Mitchell
Mojave Desert
F-150, Schwinn Beach Cruiser,
You can buy a cordless sawzall. Every manufacturer makes one. I have a Makita sawzall running off of a 18 volt battery. Get a 8-9ā€ pruning blade and you can cut wood. Makita also makes an electric chainsaw that runs off of two batteries. Pretty quiet.
@5GKennyG
Kenny
Scottsdale
On this subject, what about a coffee maker or electric griddle for a camping trip. I realize thatā€™s not true camping but it is convenient. Will either of those work? Or even an electric hot water pot?
Carolo
Chuck
Southern California Mountains
Short answer.......NO. Almost anything that uses electricity to produce heat will draw too much amperage to function on this system.
ScareCrow
Burl
Indiana
BS/Badlands
The BL 110 output is limited to 400 watts, the lower trims are 100 watts....... think light bulb... :wink:
Good for a laptop or string of LED's.
