Got my hood decal on today. Wet application was 1000x easier than the dry apply on my lady friend’s ride. Her decal we fought for two hours, with the wet application, once the liner was peeled, took 9 minutes. Getting it lined up perfectly and marked was 14 minutes. 23 minutes start to finish.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5783
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5784
Ordered some G2 caliper paint in what is the closest thing to the badlands emblem color. The color I mixed at work is much closer to the emblem, but it’s not heat rated… anyways… took my cricut machine and spent an hour getting the decal the right size and curve.
Going to let it dry overnight and tomorrow put the decals on. 😊
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_6208
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_6213
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_6212
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_6220
Looks good with the wheels back on. I’ve lost track of your mods, did you lift it and add larger tires? Looks meaner than stock 👍🏼
Correct. Bilstein B8 Terrasport and 245/65/17 Wildpeak AT4s.
Thanks. 😊
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_6229
Undercoating the bronco tomorrow. Going to get some in the doors, and up the doors (behind the plastics) to prevent any future rusting.
For anyone curious… the fender flares and door plastics are held on by a combined 72 tabs each side. 🙃
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
@Frenchy906 I've debated painting my calipers the color you did or just black. Curious to see how the under coating turns out. Good idea for your area with all the snow!
Today i detailed the outside only, and rotated the baja squadron lenses 90 degrees to the outside so the flood angle part of the lens isn't getting blocked by the hood where it sat before as the bottom row.
Ford Bronco Sport What did you do TO your Bronco Sport today? 1000092328
