Big Tires for BS Badlands
  • Thread starter Deleted member 6591
  • Start date
  • Watchers 11
Deleted member 6591
Any rubbing? Those look awsome!
Bluebaru
18 255/55 fit perfect. Same diameter as 245/65 17.
Good tires and I'm glad you like them but a 255/55/18 is 29" in diameter and a 245/65/17 is 29.5". Maybe you meant same diameter as the optional OEM 235/65/17's. A 245/60/18 is 29.6"
GulfCoastBronco
Topher
Corpus
I’m running 235/65/R18 Toyo AT3 which is a 30” tire and seems to be the biggest recommendation on 18” wheels. I love them even though they don’t seem to fill the wheel well the way 245 17’s do. But with my 1.5” lift and 1.5” bigger tire I’m sitting 2.25” higher than stock and have good room for movement when driving on the beach which is my most off roading.
Ford Bronco Sport Big Tires for BS Badlands 76E5D531-DE59-48CE-B161-889CE0A6B58C
Bronco(maybe?)
Matthew
My bad, I gained a 1/2 “ on my factory 225’s . Which only measured 27.5”’s.
255 only measure 28! On the vehicle. They still look small from full on profile. Not sure I could go any bigger without further modification, which I didn’t want to do.
I am talking on the vehicle from the ground. All the info or tire calculators stated exactly what you are.
made a huge difference and highly recommend.
stock tires were awful on the road,rain, and putrid in snow.
okay on dry dirt.
Warpious
www.floracreekplace.com
Both to tire jobs look awesome! @Bronco(maybe?) the hitch you have, is that on you ordered after market or came with? I've read in other threads the BL w/tow is supposed to come with it but I didnt see one in ours.
Bronco(maybe?)
Matthew
Tow package ordered with truck. Hitch receiver $30 on Amazon. Can post a link.
thanks for the kind words. Greatly appreciated.
Deleted member 6591
Same hitch here, but orange, as my BS is Cactus grey. Awaiting the Rhino lock to keep it in place permanently. Some people may think BS is not capable, but there are so many videos proving them wrong. Also I am sure some of us has had good experiences off-road. So those kind of additions to our vehicles are not a hype.
Warpious
I'll have to look into that ford engineer claim, I'd like to get some 255/65/17 or 245/70/17 for my badlands and I'm not a fan of spacer lifts.
The number in the article seems higher than the generally accepted 29.5 so I kept to 245/65/17. I saw someone on here put 255/55/17 on but I haven't seen larger without rubbing
If you put on bigger tires and keep the stock wheels, can you put a spacer behind the wheel? Maybe 1/8" to 1/4" thick?
notabumblebee
2022 BroncoSport
You can add a wheel spacer but based on some of the other threads you won't gain much clearance from it unfortunately.
Deleted member 6591
But does not look bad at all! That wheel well looks better filled!
