AndyMac204
Andy
I was pleasantly surprised by the price. I might just get it and see if it works. Hope for the best!
right? thats an extremely reasonable price ??
BamaBronco
TJ
Alabama
It fits nice I can take closer pictures of it if you guys would like
Maybe some underside photos of the skid plate. Also, if it's not too much to ask, could you measure the width from bolt-to-bolt of the 4 mounting points? For reference, the measurements between the bolts represented by the red and yellow lines in the picture below. Thanks!
Ford Bronco Sport Rally Innovations light bar and skid plate installed on Bronco Sport 1640046596250
Wabarca2
Wabarca2
Walter
Yea I'll try to get those to you tomorrow
vault_boy
Juan
Puerto Rico
What I kinda dont understand is what am I buying? Is just just the part that sits in front of the bumper or the entire underside too?
BamaBronco
TJ
Alabama
See the instructions I found on the skid plate's web page linked below. Looks like the plate doesn't quite cover the entire underside of the engine bay, but if it fits over the existing composite splash shield for non-BL trims, it will provide some protection and is better than nothing.
Installation Instructions
AndyMac204
Andy
yeah it looks like it is covering the coolers for the most part, which is still fine with me. now if they would cover the oil pan and that low-a$$ rear diff, that would make me a happy homer.
Wabarca2
Wabarca2
Walter
Red line measurement 38 inches
Yellow 34 inches
BamaBronco
TJ
Alabama
Yellow 34 inches
Thanks! I really appreciate it.
I measured between the gray bolts (only one side shown - labeled 1 in picture below) and the measurement was about 43-44". I also measured 36" between the two plastic grommets (labeled 2) and 33" between the two black screws (labeled 3). So unfortunately, it doesn't look like I have found the same mounting points that are on the Badlands/FE as of now. I may go fishing and start to take off the composite splash shield to see if there are any other holes underneath that would match the Badlands. If anyone else with a non-BL/FE trim wants to start looking too, please do!
Ford Bronco Sport Rally Innovations light bar and skid plate installed on Bronco Sport Bronco Underside
Martinjv71
Martin
Chicago, IL
2024 BadLands
This is the light bar and skid plate that will soon come out from them. It's paired with baja design lights and a trigger 4 plus to control the lights. The Skid Guard is 1/8" 5052 Aluminum
Ford Bronco Sport Rally Innovations light bar and skid plate installed on Bronco Sport IMG_29951
Ford Bronco Sport Rally Innovations light bar and skid plate installed on Bronco Sport 20211113_112603
Ford Bronco Sport Rally Innovations light bar and skid plate installed on Bronco Sport imagejpeg_0(1)
The way it is open in the front, it will catch too much debris not to mention highway speeds bending that back. This is a solid pass.
ctrabbit25
Carlos
Austin, tx
Rally innovations is currently making a prototype skid plate for my outer banks due to the mounting holes being different on the badland/first edition. They have great customer service and have stayed in contact with me the whole time.
