I'm in need of help. I've had my 2024 BS Heritage for 2.5 months. No problems. I got in it yesterday and it would not start. It said "no key detected
LisaMarie617
Lisa
Holland, MI
2024 Ford Bronco Sport Heritage
I don't. I was looking for loose wires or disconnections. I guess I should check if they're good. I'm getting so discouraged. I guess I will need to have it towed to the dealership.
I very much appreciate all your advice.
Birdman
Roger
Indiana
2024 BSBL
I have no experience dealing with the issues you are having, but it seems as tho many of the things I own today(phone, tv, laptop) benefit from a reboot. Maybe disconnect the battery for a few minutes?
TCBSport
Pennsylvania
2023 Bronco Sport, 2012 Land Rover LR4 5.0L
Call the dealer to see if they will tow it. If not do you have AAA? I use them all the time.
rugedraw
Javier
Miami, FL
If your Fordpass is connected, message me the VIN and I can check any codes it may be reporting.
LisaMarie617
Lisa
Holland, MI
I agree. I did try that.
rugedraw
Javier
Miami, FL
On 10/1, the truck reported these codes. Only the top two are active faults; the rest are stored codes than can be ignored. The U3000 code is an internal electronic failure in the BCM and the other BCM code cites a short circuit to the ground.
Ford Bronco Sport I'm in need of help. I've had my 2024 BS Heritage for 2.5 months. No problems. I got in it yesterday and it would not start. It said "no key detected 1760022209989-el
The last time it reported any data to the cloud was 10/3, and the codes are below. The BCM U3000 changed to a stored code and no longer an active fault, but the left door handle prox sensor is still an active fault.
Ford Bronco Sport I'm in need of help. I've had my 2024 BS Heritage for 2.5 months. No problems. I got in it yesterday and it would not start. It said "no key detected 1760022298900-9c
If I had to guess, the door handle sensor is the problem and not the BCM, but without being able to plug into the car directly and run pin-point tests, it is impossible (for me anyway) to diagnose remotely. However, it does seem like a dealer visit is warranted.
BLUEOVALRACER
Ohio
Very Good Information thanks for trying to help out the OP.
TCBSport
Pennsylvania
I wonder if the main battery is so low the key fob receiver has no power. Have you tried jumping the car yet?
LisaMarie617
Lisa
Holland, MI
Now that I'm bringing it to a mechanic, how do I get it in neutral?
With both keyfobs dead, putting them in their center console special place doesn’t work and a dead 12V battery - that’s an interesting conundrum
even if you had a jump battery or installed a fully charged 12V battery the 2024s are difficult (but not impossible) to get into neutral
The procedure is probably in your owners manual maybe but if not there is a forum post with the instructions - there is a special “tool” probably in your glovebox
Check around Post #19:
https://www.broncosportforum.com/forum/threads/2023-emergency-neutral-procedure.9624/post-189872
LisaMarie617
Lisa
Holland, MI
I stumbledupon another possibility.
A TPMS warning code came on. The tire psi is fine. I just read that a faulty tire sensor can create the inability to read the key fob. Thoughts?
