I'm in need of help. I've had my 2024 BS Heritage for 2.5 months. No problems. I got in it yesterday and it would not start. It said "no key detected
rugedraw
Javier
Miami, FL
I stumbledupon another possibility.
A TPMS warning code came on. The tire psi is fine. I just read that a faulty tire sensor can create the inability to read the key fob. Thoughts?
I got your message and I did a little Googling and found people have reported TPMS warnings causing issues with the key not being recognized. However, I don't think that's the case. I think whatever is causing the key fob to not be recognized may also be causing the TPMS warnings as both are functions controlled by the BCM.
The one thing you can try is to disconnect the negative cable from the 12v battery for 20 minutes. This will cause a hard reset of the entire module network. If that does not work, then take advantage of your factory warranty and let the dealer figure it out.
LisaMarie617
Lisa
Holland, MI
2024 Ford Bronco Sport Heritage
Thank you so much for all of your advice. I appreciate your time to help me. I do have an upcoming appointment with the dealer. When I get home from work today I will disconnect the negative cable. I'll keep you updated.
rugedraw
Javier
Miami, FL
Not sure of a way to get it in neutral, but when you call roadside assistance or AAA or whatever you plan to use, tell them the vehicle cannot be put in neutral and you need a traditional type tow truck (not a flat bed) with dollies so they can take it to the dealer without having to drag it onto a flatbed and risk damaging the drivetrain.
Ford Bronco Sport I'm in need of help. I've had my 2024 BS Heritage for 2.5 months. No problems. I got in it yesterday and it would not start. It said "no key detected 7.1.2-Dollies
rugedraw
Javier
Miami, FL
@LisaMarie617 I asked a member on the Bronco forums who is a Ford tech, and there is a way to get it in neutral if you need to. See attached.
cprcubed
Patrick
Parker, TX
I vaguely remember that the procedure for 2023 and up BS may be different, but my 2022 Owners Manual has a "Manual Park Release" procedure under the Transmission section (so maybe see what your Owners Manual has to offer. Cheers!
Similar info was posted way back in post #28 which is repeated here:
btw the link below and its reference to #19 probably is not as up to date of a procedure as rugedraw posted above in #35
With both keyfobs dead, putting them in their center console special place doesn’t work and a dead 12V battery - that’s an interesting conundrum
even if you had a jump battery or installed a fully charged 12V battery the 2024s are difficult (but not impossible) to get into neutral
The procedure is probably in your owners manual maybe but if not there is a forum post with the instructions - there is a special “tool” probably in your glovebox
Check around Post #19 (in link below):
https://www.broncosportforum.com/forum/threads/2023-emergency-neutral-procedure.9624/post-189872
LisaMarie617
Lisa
Holland, MI
Rockboz
Randy
South Lyon, MI
I am truly sorry for your situation and the amount of time this is taking. After looking at the procedure on how to get it into neutral, with tools and everything, thank God I still drive a manual transmission.
LisaMarie617
Lisa
Holland, MI
I need to vent. I followed the directions to a T to put the Bronco in neutral with the pin. It went smoothly as illustrated. BUT still not in neutral!!! I disconnected the battery so the parking brake wasn't engaged. I was hoping to get it in neutral for the tow truck person. Oh well. I'm not quitting my day job.
That vehicle has certainly been one PIA
And you haven’t owned it all that long, if you could track down the former owner they probably would have some useful info
cprcubed
Patrick
Parker, TX
Is your BS still under warranty? Maybe check to see your dealer offers mobile service. I had a couple of recalls done at my house. Cheers!
Mwittke5857
Elma, NY
2021 Bronco
I'm in need of help. I've had my 2024 BS Heritage for 2.5 months. No problems. I got in it yesterday and it would not start. It said "no key detected ". No problem. I went and got my spare key. Said same thing. Changed batteries, same thing.
Did all of " the tricks". The key fob is not the problem. I read to check the RKE antenna connection. That it has had problems coming loose. Was told it's inside the rear back left panel. Took that apart. Did not see anything that looked like the RKE antenna. Uggg. I spent half the day trying to find videos or any info about this. Can anyone help me? I've been without for 3 days.
Thank you 😊
Happens to me every so often. I just hit the panic button, cancel it and I've been good to go.
