Mini-Spare diameter - why not 29" or so?
watt-man
Phoenix
25 Bronco Sport
I just bought a '25 Bronco Sport for the wife, so I'm new here. I was surprised that the stock tire diameter is nearly 29 inches, but the donut-spare (155/70-17) is 3 inches smaller (under 26)! I have no experience with 'new car' RDU / PTU function (I'm used to Traction-Lok units from the past that wear out when you mess with dis-similar diameters) - so I wonder why Ford didn't have the donut-spare at a 155/90-17 instead. It would put the diameter much, much closer. Or a 165/90-17 to really nail the diameter, but I don't want to get into a tire-width discussion and full-size spares.
So it would seem that Ford feels the 10% difference in tire diameters is "bad enough you should repair it right away"... yet they could have just reduced this difference to 1% or 2% by upsizing the donut-spare sidewall height slightly - (in fact, the 90 series sidewall tire is cheaper at Discount than the 70 series!).
Text from the owners manual is attached. Being okay with a donut-spare width, I'm inclined to spring for a 90-series sidewall tire on the donut-rim on a '35,000-dollar-loaded-with-4WD-electronics' car. Just wondered if others have any proof that the 3" tire diameter doesn't cause damage, even though Ford thinks it's a big enough deal to put it in the manual. This seems to be conflicting advice, I think I'll rest easier with a 155/90 or 165/90.
Thanks in advance if you have some data on this.
Ford Bronco Sport Mini-Spare diameter - why not 29" or so? spare-in-manual-
Even though mine came with a full size tire, I opted for a new take off rim off of EBay and the same optional Wildpeak tire.
The option now is no tire and an inflator. While that might be fine for a vehicle that gets a nail in the tire, it won’t help much 30 miles from the main road with a cut tire from a ledge or sharp rock IMO.
I’m sure it was all done for cost control and weight reduction.
Ernest T
Dennis
Central Texas
2025 Bronco Sport, 2017 Ford F150 4X4, 2014 Jeep Cherokee 4X4
Wha trim do you have? I just bought a Badlands and it’s got the same size spare, 225/65 R17, as the other 4, but it’s a Pirelli Scorpion.
Ford Bronco Sport Mini-Spare diameter - why not 29" or so? IMG_6600
Ford Bronco Sport Mini-Spare diameter - why not 29" or so? IMG_6601
2025 Badlands Sasquatch
The Badlands Sasquatch has Goodyear Territory A/T 235/65 R17's. My spare, however, is the 225 Pirelli like yours.
My 2022 Badlands came like some ‘25s - 4 Pirelli Scorpions and same size spare 225/65 R17 but not to worry most owners get around 25k miles with those
I’m hoping owners get over 50k miles with the Goodyear Territory A/T 235/65 R17
While I want a long-lived tire, I also wouldn't mind an earlier excuse to get something a little more common (and fun).
Don't get me wrong, the Goodyears appear to be a solid tire, though I've only got about 1,600 miles (all paved roads) so far.
Lots of owners like those Goodyears! I wanted to purchase a set but my OE tires wore out too soon (didn’t find the 2025 tire without the Wrangler logo until earlier in 2025 at least 6 months after I had already replaced my OE tires)
Bill G
San Gabriel Valley, CA
While changing to a taller “donut” spare would solve the mis-match affecting the AWD on-road (snow, rain, etc) it wouldn’t solve an off-road situation IMO. The “donut” spares require high air pressure which would, I think, make for a problem in the “dirt” and with rocks. If you’re going off-road I’d go with a “real” spare, if not the “donut“ would probably be fine.
Reactions: Me3
"Spare" is not "replacement", at least where it comes to the donuts. They are there to simply limp you to the nearest tire shop for a proper repair or replacement.
Me3
Paul
Northern Nevada
RAV4
What don’t you like about the Goodyears? They look aggressive and are fairly quiet from what I’ve read here. Not that I care for Goodyear, since they moved out of Akron. I grew up near there and they used to fly the old giant blimps around all the time. But I’ve only heard good things about them so far.
I don’t dislike them, but they’re a bit of a unicorn right now. There’s several other A/T’s with a broader range of sizes.
watt-man
watt-man
Phoenix
25 Bronco Sport
Full agreement with both of you. This is a street car, the wife really likes the looks of the Heritage model (probably was an easy sell to me as my car is a 1966 as well) and we were in the market for a newer car for her. I wouldn't want to use a donut spare in an off-road situation, but I do want the donut spare to match the diameter of the others within reason. A 3" difference just seems silly.
watt-man
watt-man
Phoenix
25 Bronco Sport
Thought I'd close this subject with some final data. This is not a "full-size vs. Donut spare" discussion, I get that, but for those who want a donut spare to have an appropriate "matching" diameter, I'm happy to say that I found a good solution.
All tire diameters quoted below are inflated but not supporting the vehicle. Just wanted all numbers to be apples-to-apples.
My Wife's 2025 Heritage has a stock tire diameter of 29 inches. Given that the owner's manual makes such a big deal about matching tire diameters on all four corners, it's crazy that the stock donut spare on the '21-'24 models is 25.25 inches. See photo below, it's crazy.
I installed a Falken 165/90-17 tire on a '21-'24 rim, the diameter is just where we'd like it to be... at 28.9 inches. No photo required, it matches her normal tires in terms of diameter.
We've gone from a 13% mismatch to half a percent mismatch. Hope this helps others.
Ford Bronco Sport Mini-Spare diameter - why not 29" or so? Stock Donut
