- First Name
- Sherman
- Joined
- Dec 1, 2021
- Threads
- 29
- Messages
- 1,829
- Reaction score
- 1,884
- Location
- MIDDLETOWN, MD
- Vehicle(s)
- '22 Badlands ordered 12/17/2021 - Arrived 3/25/22
- Thread starter
- #1
Yesterday, I changed the oil in our Badlands. It was the 3rd time I've done it so it was a little easier, but not by much.
Some notes for general information:
* Oil filter: When removing the filter it leaks oil as soon as the gasket is no longer in contact with the mating surface. This isn't too bad if you're aware of it and have the drain pan under it. Once the oil stops leaking out you can remove the filter, but as soon as it's free, more oil comes gushing out. Forum members have mentioned using a plastic bag around the filter to catch the oil. I haven't tried that but apparently it works well.
* Draining the oil: It's straight forward, but keep in mind that when the plug is removed the oil will initially shoot out toward the front. As the rate of flow decreases the stream of oil will move backward toward the drain hole and then end up flowing toward the rear of the BS. A typical 5/6 quart drain pan must be moved from front to back to catch the oil. I found that if carefully positioned, a large 15 qt. pan does not have to be moved. Unfortunately, I did not have mine positioned quite right and when I wasn't looking the stream of oil moved backward beyond the pan and there were a few ounces on the blacktop. Sawdust picked it up.
* Skid/bash plate: R&R is no problem, the 2 bolts in slots really help. There can be dirt on top of the plate so protect your eyes. The problem I've run into is getting the 4 speed nuts (for the screws that retain the plastic) into position. What I've been doing is installing the skid plate bolts first but leaving them loose so the plate can slide. Even then, getting those screws started is tight.
This oil change only cost $24 -- but it is more work than usual.
I hear there are actually places that will change the oil for a fee, while you wait -- but what fun would that be?
