- First Name
- Tomas
- Joined
- Jun 2, 2024
- Threads
- 7
- Messages
- 1,089
- Reaction score
- 1,465
- Location
- Sacramento
- Vehicle(s)
- 2024 Bronco Sport Badlands
I forgot about the non fix ford did for leaking fuel injectors. Which are directly injecting fuel into combustion chamber as well as port injection. Weather you want to consider that internal or not that's still a major function of an engine, that if fails could cause a fire.Water Pumps and Leaky Fuel Injectors and what else?And FWIW those are external parts not really Engine Related.What internal engine problems have you heard about on the 1.5?
The water pump is externally mounted sure, definitely need that working to keep engine cooled. Get a leak and loose fluid you get less cooling protection. Overheating could cause internal damage to engine components.
I just don't want to have to monitor if my water pump is leaking or not today. To me the 1.5L is a time bomb, literally. I don't trust ford's drain tube as a fix when fuel and hot surfaces combine. They should install better injectors under warranty for every 1.5L out there.
