- Thread starter
- #1
In case you couldn’t tell, I despise loose wires
These are Rigid Ignites, they make a bracket specifically for the Bronco Sport. They can be angled and put out a ton of light for their size. I wanted to be able to throw a bunch of light around the car when setting up for camp, or angled forward for better visibility on the sides of the trail. I’ve got two per side, each side pair controlled by its own switch.
I spent a lot of time making cables to make sure everything was nice and organized. I have 6x fused relays off the battery, controlled by 5x switch inputs from the cabin (I have an extra). At the moment it controls a set of lights on each side of the roof….but now I’ve got easy expansion if/when I need!
Everything is on waterproof plugs so I can easily swap around which switch controls which line. Everything is routed seamlessly through the body panels up the A pillar and tucked under the top rails to hide all the cabling
I covered the switches in a separate post. Overall stoked on how this project came out!
