Quashish Family Ride Thread : 2024 Badlands
Quashish
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
Rear bumper lights arrived today so had to do a quick bench test.
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20240919_170452
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20240919_170455
So with those working I went ahead and ran power wires for a switch and a signal wire from switch location to the rear bumper area. Just in time with the sun going down.
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20240919_191238
Purple wire is my power for high setting I will be using as rear fog.
I'm going to make a small box to mount the switch inside and mount box under the seat. Pretty crude solution but I hate the idea of drilling into the dash for a switch. It's a temporarily permanent solution as I may later be using an aux beam switch controller for all auxiliary items.
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20240919_192225
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20240919_192249
Power and ground are ran from passenger footwell fuse panel, across to driver side and tucked under center console trim towards the back of drivers seat and then turns forward.
Signal power wire is joined under the seat (will be zip tied out of the way) and ran under B pillar and rear driver side door trim, behind rear cargo trim and through a hole I found into area behind tail lamp harness plug, then neatly ran through that harness plug sleave and taped back up neatly. Ready for further install.
Quashish
Quashish
Tomas
Sacramento
Installed the rear bumper lights/ rear fog lights
Also put the underground graphics light smoke overlays on the front and rear bumper markers, and over the clear portions of the reverse and signal areas of the tail lights.
Not great pics but also in full daylight
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands VideoCapture_20240921-212819
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands VideoCapture_20240921-212823
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20240921_132629
I really like how the blacked out rear lights blend into the bumper when off. My only gripe would be how the led design of these Chineseium lights don't match the factory lighting. But it's whatever.
I liked having the rear fog in my old accord because I could flick it on when someone was riding my ass and they would fall back. So now research and development needed on these. But they're decently bright in person
Quashish
Quashish
Tomas
Sacramento
............................................ so far installed
- hood deflector
- K&N intake filter
- vinyl windscreen topper
- footwell lights
- factory front and rear mud guards
- Full LED tail lamps
- bronco hitch receiver plug
- all weather mats
- forscan programming
- glass screen protector for center display
- water spot removal and paint protection
- factory window vents
- fender signal markers
- black Ford emblem
- ditch lights
- yakima HD crossbars
- rooftop basket
- swap the Falken wild peak 235 for toyo AT3 245
- tint windows
- rear license plate reverse light bar
- Dash cam
- rear reflector running light/ rear fog
- light smoke overlays
Still Need
- under hood sides weather seals (sent a text today for update, didn't hear back.)
- diy front seat jacker
- run fuel line through firewall to hood seal
- real lug nuts
- add ambient lighting under rear of front seats for back row illumination
maybe
- molle rear hatch panel
- molle cargo area window panels
- upgrade spare pirelli scorpion 225 to matching toyo 245
after that i think we'll be pretty solid.
any suggestions or ideas are welcome
Jmuns
2022 Bronco Sport BL
- hood deflector
- K&N intake filter
- footwell lights
- all weather mats
- black Ford emblem
- ditch lights
- rooftop basket
- tint windows
- Dash cam
Still Need
- real lug nuts
maybe
I’d search the forum for the molle rear hatch. I feel like someone had either videos or real world experiences testing different weight on it and the amount that it takes for the struts to close. Just a thought before you make the investment. Think about what you’d realistically want to put there versus what you can without having the hatch close.
Definitely get another 245 to match. It’ll fit. You just need to take the padding out from underneath the existing spare.
Quashish
Quashish
Tomas
Sacramento
I've heard it's about 7 lbs. It would be a down the road addition. Right now the only thing I can think of putting up there is the ford first aid kit and maybe a flashlight
Quashish
Quashish
Tomas
Sacramento
Got back from our first road trip with the new car. Took a trip to the coast. Stayed in fort Bragg for the weekend. 2 tanks of gas. Filled up before we took off, and refilled before we came home. Only burned through little more than half a tank coming home. averaged 19.7 mpg over 430 miles and 10+ hours of drive time.
Not bad. I care more about smiles per gallon than MPG. also keep in mind this is with the 245 toyo tires and the roof baskert still on even though we didn't need it this time.
Overall it did great. Handling on the twisties of highway 20 through the redwoods was great, out performed my expectations especially being much taller than my ST. the automatic transmission wasn't laggy or harsh either during shifting though the power band.
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20240928_085356
Nice to get away from the heat. And celebrated my wife I's 10 year anniversary. Only pic I took there outside out air B&B
Came home today and installed the tackmount system. Would've been nice to have it on the trip but got delivered after we left.
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20240929_181331
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20240929_183731
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20240929_183753
Also the permanent license plates were waiting for me in the mailbox and I threw those on as well.
I've got the gorilla lug nuts waiting to go on. Hopefully tomorrow morning.
Quashish
Quashish
Tomas
Sacramento
Had to take the wife's car to the dealership Friday just to get the side hood weather seals put on because it was under "warranty" they wouldn't just let me pick upthe parts. So had to wait around for an hour just for that. But they're on. No missing parts not counting the engine cover.
I swapped the factory lug nuts for some solid ones. Always had gorilla spline style lugs on all my vehicles. So went with those.
While wheels were off, I removed old wheel weight adhesive ford didn't remove when swapping tires. And somewhat color matched the new weights because I'm obsessed
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20241004_195816
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20241004_200542
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20241004_201020
This morning I detailed the inside and out real quick after adding rear lighting to match the front.
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20241004_214501
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20241005_091914
Quashish
Quashish
Tomas
Sacramento
............................................ So Far Installed
- hood deflector
- K&N intake filter
- footwell ambient lighting front and back
- all weather mats
- factory window visors
- black Ford emblem
- ditch lights
- rooftop basket
- tint windows
- Dash cam
- tackform dash mount w/dual wireless phone charging mounts
- rear reflector running light / rear fog
- under hood side weather seals
- run fuel line through firewall hood seal
- real lug nuts
............................................ Still Need
- ambient light in pocket area above shifter
maybe
@Quashish … what is the part # or a link to the gorilla spline style lugs? Are you happy with that brand? Thank you
Humper
Mick
Oklahoma
Do you have part numbers for the underhood weather seals and a link to the Gorilla lug nuts.
Thanks
Quashish
Quashish
Tomas
Sacramento
Gorilla Automotive 21133BC Small Diameter Acorn Black 5 Lug Kit (12mm x 1.50 Thread Size) - Pack of 20
https://www.amazon.com/Gorilla-Automotive-21133BC-Diameter-Thread/dp/B001O0AMZS/ref=mp_s_a_1_1?crid=19832EGKFGXPF&dib=eyJ2IjoiMSJ9.5tTwn5UJ3P6UjPelktKh9Fk__IbRNvldLMl8hfsq1iNx2Af4AE-eOVdDQhav8FyJZI41JVmcJkpYl48OvBjt0Q56-h3Ub62Y56sG5_wbtqjXSq3r5dXfzrZDZ8AshggvpwjFjL7ufsq0Dxn6dBbMJxfCfJVvhQ4bcvYpJ2szlQnk1SxGAa5_8U4U33DxvxDkhk_9gRFugUSt4Ls9H4M5Iw.jV1OnRRh3GS7CKORDny8U3sUNc_08HOUh4lwxuMngSI&dib_tag=se&keywords=m12+x+1.5+lug+nuts+gorilla&qid=1726988605&sprefix=m12+x+1.5+lug+nuts+gorilla,aps,161&sr=8-1
Avaliable on Amazon. But most reputable online sources sell them too
had these these on 4 vehicles either black or chrome. They keep their finish well, and add a small layer of security.
Quashish
Quashish
Tomas
Sacramento
Thanks
I had to give these numbers to the dealership at least 3 times before they came in.
Hood weatherstrip Left: M1PZ16A239A
Hood weatherstrip Right: M1PZ16A238A
DahliaDarlin'
Lise
New England
I have enjoyed reading this thread although I have no idea what half.... OK 7/8 ths of the things you've installed actually do. Particularly that do-hickey next to the screen that let's you hang two cell phones (?) off of it?
It amazes me that you can buy a new car and then just blithely pull it all apart and fiddle with the wires, etc.
What is a side hood guard?
I am thinking of getting the cute hitch plug, just as an anti-goop device.
Keep up the good work!
