Frosty
Dennis
Leather cup holders, console pad, seat belt cover, and roof rack cross bars.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0422
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0419
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0477
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0658
Gotta ask. Where did you find THOSE seat belt cover pads? We have a set that only has BRONCO in big white letters. Like yours MUCH better!
GEOGRL
Kim
2024 Bronco Sport
I got them on ETSY and asked if they could put Sport under the Bronco.
BLUEOVALRACER
Ohio
Not today, but earlier this week. Swapped out the factory steel rims for some gloss black ones. Looks much better.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5639
Looks good i didn't know you could get the steel rims on the Big Bend until i looked in the 2022 Bronco Sport Brochure and it looks like they were an option?
JakeNB
Jake
NB Canada
2024 BS
My mistake- they are actually 17” Carbonized Grey-painted Low Gloss Aluminum Wheel that come with the Black Diamond package. They look like steel winter rims.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5657
Humper
Mick
Oklahoma
Added OEM ambient light in the cubby / charging area and whilst I was in there added another 12v outlet and a 12v display, did not loose any room for phone charging.
Ford Bronco Sport What did you do TO your Bronco Sport today? 1000005183
Ford Bronco Sport What did you do TO your Bronco Sport today? 1000005182
gatornek
Miami
Installed HRG molle panel. Easy install and seems pretty solid
Ford Bronco Sport What did you do TO your Bronco Sport today? moll
How are these holding up?? Still rock solid, even after adding weight? The install is essentially just tapping into the plastic panel behind the liner?? What exactly are the screws tapping?
I think they are a great spot to add extra cargo space for the BS, but I worry, that they'll just fall off after a bit.
EARLSAYS
Earl
Houston
Which wires do you need to splice into to light those up? I have the lamps installed, but my badlands did not come with ANY ambient lighting wiring....I need figure out which wires to tap into.
Horse n Buggy
Stoge
Florida, USA
I'm not Bill but I have these installed on my car. They are secured with 6 self tapping screws, two in the roof liner (they only tap the liner) and two in each of the side plastic trim panels (tapped solely in the plastic trim).
I wouldn't go ham with loading them, but small tools, med bags, flashlights and whatever else feel very secure when mounted. You would have to start hanging hammers on them to get sketchy with the mounting.
Ford Bronco Sport What did you do TO your Bronco Sport today? 1000005015
Ford Bronco Sport What did you do TO your Bronco Sport today? 1000005016
