BritNowInOhio
Ian
Lost in Ohio
Now I’ve got mine back, I want to get around to fitting the coloured badge decals I got a while back.
I got yellow because I’m a fan of the classic BRG and yellow, like on the classic Lotus 7 featured in The Prisoner.
Mighty3
Al
Long Island NY
Saw these at Lowe's. $12 for 5 of them with replaceable batteries. Stuck one in the cubby by the USBs and 12 volt socket. Good for those of us who don't have the lit up rings. Lux Pro #LP172. Rated at 16 lumens, has a push on push off tap switch and says its good for 10 hours. Works great. About the diameter of a quarter and maybe .5 of an inch high.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240728_145912
Leeford
Lee
Ontario, Canada
bronco sport
Replaced the rear wiper blade — again. The front wipers seem to hold up, but the rear blade keeps rotting out for some reason. Today I replaced it using the rubber purchased on Amazon. Easy to do once you figure out how to pry off the wiper and the end cap without marring them. Only problem I had was keeping the two thin strips in place while inserting the blade with my arthritic fingers!
Whole job took maybe ten-fifteen minutes, and each Amazon strip makes (3) refills — so next time will be quicker; probably a five minute, $1.00 job instead of the $40 from the friendly Ford dealer ?
where did you get the strips?
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
don't ask what your Bronco Sport can do for you
but what you can do for your Bronco Sport
tangential but relevant
beta testing
new approach to asphalt driveway crack sealing
hot glue
pros:
  • great flow-ability even in the smallest of gap
  • tight bonding to surfaces
  • black color matching
cons:
  • time consuming
note - sealer had properly adhered to glue material
BritNowInOhio
Ian
Lost in Ohio
Finally had a free few moments to put them on.
I know this colour combination isn’t to everyone’s taste but I love it.
Also should note the yellow looks better in real life than this picture suggests.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_3546
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_1694
Luis@UG
Luis
Houston, Texas
2022 Ford Bronco
Lotus British Racing Green with a yellow colors (stripes) dates back to at least 1963 to signify the cars of Hethel.
Can't wait to see what else you come with.
I vote for a Ford Bronco Sport - Lotus Livery.
Bill G
San Gabriel Valley, CA
Odd question, could you provide a rough measurement for the length and height of this area of the molle panel?
Ford Bronco Sport What did you do TO your Bronco Sport today? 1722269829861-bt
Approx 12” high, 15” front to back at the top and 7.75” at the bottom. These are pretty rough measurements of the window opening. The panel is slightly smaller leaving room for the “brackets” to be forced into position against the plastic window trim and screwed in.
Hope this helps.
BritNowInOhio
Ian
Lost in Ohio
And now the back.
The P and the R were nightmares, the T literally went straight on, first time.
I did also have hinge covers for up top on the boot but unfortunately they proved a step beyond my patience/skill level and I gave up with the test piece they’d provided.
Respect to people who work with graphic and vinyl, your patience and skill far outweighs mine.
If anyone would like yellow trunk hinge covers, hit me up.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_3549
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
are those overlay vinyl letters just from amazon? ive seen the letters that go completely over the existing but idk if i want to pay that much for colored letters.
